need to know once and for all
Old Mar 14, 2006 | 02:09 PM
hondatuner20's Avatar
Default need to know once and for all
can a bad input shaft bearing cause grinding of gears? because once in a blue moon my 3rd gear will grind then the next day i will wake up and rev it to 8grand and slam it into 3rd and it will be fine. my input shaft bearing is crap i can hear like woah.
Old Mar 14, 2006 | 02:16 PM
Runnerdown's Avatar
Default Re: need to know once and for all (hondatuner20)
the grinds tend to be much worse when trans fluid is fully warmed up and thinner. cold fluid seems to be enough sometimes to keep it from grinding. change the bearing you are ruining the transmission.
Old Mar 14, 2006 | 02:18 PM
RCautoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondatuner20 &raquo;</TD></TR><TR><TD CLASS="quote">can a bad input shaft bearing cause grinding of gears</TD></TR></TABLE>
No
Old Mar 14, 2006 | 03:23 PM
Default Re: need to know once and for all (Runnerdown)
so is thats whats causeing it? the tranny was fine before the bearing started to go.
Old Mar 14, 2006 | 03:34 PM
Runnerdown's Avatar
Default Re: need to know once and for all (90blackcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">
No</TD></TR></TABLE>
well, when they get bad enough it can cause grinding. I fixed a 97 civic one time that had gotten so bad it popped out of gear, grinded and was almost undrivable. it had about a quarter inch play in the shaft when I wiggled it
Old Mar 14, 2006 | 03:46 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Runnerdown &raquo;</TD></TR><TR><TD CLASS="quote">
well, when they get bad enough it can cause grinding. I fixed a 97 civic one time that had gotten so bad it popped out of gear, grinded and was almost undrivable. it had about a quarter inch play in the shaft when I wiggled it </TD></TR></TABLE>
The bearing itself can grind, but it won't cause your gears to grind.
Old Mar 14, 2006 | 04:27 PM
Runnerdown's Avatar
typically no.
I like that answer better, because I have experienced otherwise on two seperate occasions/vehicles.
Old Mar 14, 2006 | 04:46 PM
ludesrv's Avatar
Replace it. If that doesn't do the trick, it's your syncros.
Old Mar 15, 2006 | 01:07 PM
Default Re: (ludesrv)
bump for more opinoins
Old Mar 15, 2006 | 01:19 PM
si0385.'s Avatar
Default Re: (hondatuner20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondatuner20 &raquo;</TD></TR><TR><TD CLASS="quote">bump for more opinoins</TD></TR></TABLE>
imo get a new tranny... i had a bad input shaft bearing in my dx trans all it did was howel/grind until i pressed the clutch in than it would go away
Old Mar 15, 2006 | 08:38 PM
jdeemseerx's Avatar
a new tranny for a 40 dollar bearing? youd have to go through the same labor anyway to put a new trans in.. come on get the bearing and throw it in..and no bad input shaft bearings cannot cause gears to grind
Old Mar 16, 2006 | 08:44 AM
Default Re: (jdeemseerx)
unsure form your post what u ment any way heres the dilemma i could get a b16 tranny for 400 pluss 100 for a buddy of mine to throw it in. or how much do u guys thknk it would be for a tranny shop to take mine out replace the bearing and syncro and bolt up a new clutch for?
Old Mar 16, 2006 | 11:42 AM
92 si hatch's Avatar
sounds like syncro's
innes887
Nov 18, 2007 06:01 PM
speedysohc
Apr 24, 2007 07:24 AM
greentrbo95gst
Mar 4, 2005 02:12 PM
Del_Slowest
May 2, 2004 06:49 PM
Integra_Boi
Oct 24, 2003 07:38 AM
