unknown OBD2 code?
i have a 2000 civic coupe w/ 97 b18b swaped.....the other day i threw check engine, i scanned it with my scanner and looked up "code 1399" in the honda/acura haynes book, its not there...anyone know what it is? or does this code even exist?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BUNNYz »</TD></TR><TR><TD CLASS="quote">that is a factory code. </TD></TR></TABLE>
yep. And it's not defined in the Helm manual from what I can see. But I'm 99% sure it's general misfire.
http://obdii.com/dtcanatomy.html
P - powertrain(see honda's ECU)
1 - MFG code
3 - ignition systems or missfire
99 - fault??
which ECU are you running?
what are the car's symptoms?
1 - MFG code
99 - fault??
