Drag radial tires
Old Mar 14, 2006 | 12:53 PM
faSHOwidIT's Avatar
Default Drag radial tires
Are 225/50/15s too big for 170hp ls/vtec? will it be too hard for the tranny? can it cause too much drag?
Old Mar 14, 2006 | 01:35 PM
hondaguyef's Avatar
Default Re: Drag radial tires (faSHOwidIT)
Depending on what Tranny you are using the only thing I'd be worried about is falling out of the Power band. If using a B16/ITR trans you should be fine. If using the GSR or LS trans, I'd go w/ the 205/50's.
Phil
Old Mar 17, 2006 | 01:30 PM
faSHOwidIT's Avatar
Default Re: Drag radial tires (hondaguyef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaguyef &raquo;</TD></TR><TR><TD CLASS="quote">Depending on what Tranny you are using the only thing I'd be worried about is falling out of the Power band. If using a B16/ITR trans you should be fine. If using the GSR or LS trans, I'd go w/ the 205/50's.
Phil</TD></TR></TABLE> using 4.7final drive on 97spec itr tranny.
pasaunde
Mar 31, 2007 07:50 PM
94CivicRally
Sep 30, 2006 07:53 AM
redDAinteg
May 16, 2005 03:17 PM
june
Feb 9, 2005 01:49 PM
cliff666
51
May 4, 2004 05:58 AM
