Help w/ ITR Intake Mani & Throttle Body
Old Mar 14, 2006 | 11:44 AM
blue92da's Avatar
Default Help w/ ITR Intake Mani & Throttle Body
I just bought an ITR intake mani, tb, fuel rail, and fpr.
I have a 2nd gen B16A2 motor.
Q1. Do I need to get ITR injectors to run w/ the ITR fuel rail or can I just use my existing B16 injectors?
Q2. Do I need to get new rubber fittings/O-rings that go in between the fuel rail and the intake mani or can I just use the existing ones?
Q3. Is there a gasket that goes in between the intake mani & throttle body or is it just some kind of a sealant/glue type material?
Old Mar 14, 2006 | 11:47 AM
ralphie14's Avatar
Default Re: Help w/ ITR Intake Mani & Throttle Body (blue92da)
1. use stock B16 injectors
2. you can re use the rubber o rings
3. there is a gasket you will have to buy.
Old Mar 15, 2006 | 02:34 PM
blue92da's Avatar
Default Re: Help w/ ITR Intake Mani & Throttle Body (ralphie14)
Hey thanks for the info! Bye the way, what kind of gains if any could I expect by just doing these upgrades to my B16?
Old Mar 15, 2006 | 03:41 PM
808_si's Avatar
gains from an IM usually come with other mods working together like better cams, header, etc... I'd actually wait to install it if you have a stock b16...
Old Mar 15, 2006 | 03:53 PM
GetawayInMoscow's Avatar
Default Re: (808_si)
You will probably lose a lot of mid range power and pick up SOME power after like 6k. So pretty much your car is slower and now you have less money.
Old Mar 20, 2006 | 07:01 AM
blue92da's Avatar
Default Re: (GetawayInMoscow)
Hey thanks for the vote of confidence. I suppose your probably right.
BEfab
Nov 4, 2016 06:55 AM
HamiltonRex
Oct 27, 2004 06:11 AM
Fred n J_v2.0
Mar 13, 2003 04:51 PM
JdMcRxSi
Mar 11, 2003 03:16 PM
