Help w/ ITR Intake Mani & Throttle Body
I just bought an ITR intake mani, tb, fuel rail, and fpr.
I have a 2nd gen B16A2 motor. Q1. Do I need to get ITR injectors to run w/ the ITR fuel rail or can I just use my existing B16 injectors? Q2. Do I need to get new rubber fittings/O-rings that go in between the fuel rail and the intake mani or can I just use the existing ones? Q3. Is there a gasket that goes in between the intake mani & throttle body or is it just some kind of a sealant/glue type material? |
Re: Help w/ ITR Intake Mani & Throttle Body (blue92da)
1. use stock B16 injectors
2. you can re use the rubber o rings 3. there is a gasket you will have to buy. |
Re: Help w/ ITR Intake Mani & Throttle Body (ralphie14)
Hey thanks for the info! Bye the way, what kind of gains if any could I expect by just doing these upgrades to my B16?
gains from an IM usually come with other mods working together like better cams, header, etc... I'd actually wait to install it if you have a stock b16...
Re: (808_si)
You will probably lose a lot of mid range power and pick up SOME power after like 6k. So pretty much your car is slower and now you have less money.
Re: (GetawayInMoscow)
Hey thanks for the vote of confidence. I suppose your probably right.
