will these parts swap onto a 91 crx si
Old Mar 14, 2006 | 11:41 AM
classciv's Avatar
Default will these parts swap onto a 91 crx si
looking into buyin a 91 crx si. it is wrecked on the right side i have a few parts cars and i need to know if parts will swap over. any info would be great. thanks
right fender off a 90 dx hatch
radiator off a 90 civic 4 door lx
hood off a 90 4 door
headlight off a 90 4 door
i think that was all that was damaged. i havent looked at it yet but that is what i was given. also how much do you think this is worth, a 91 crx si with 240k needs typical body work, cracked windshield and needs all that stuff listed above let me know what you think. thanks
Old Mar 14, 2006 | 11:43 AM
si0385.'s Avatar
i remember reading a post a while back that said the 4 door hoods are different
Old Mar 14, 2006 | 12:16 PM
classciv's Avatar
Default Re: (si0385.)
i know that the hinges are different but i didnt know about the entire hood anyone else have any info?
Old Mar 14, 2006 | 12:18 PM
wood's Avatar
Default Re: will these parts swap onto a 91 crx si (classciv)
Crx fenders are also different. I wouldn't give more than $500 for a crx with front end damage unless it was minamal, and the rest of the car was in great shape.
Old Mar 16, 2006 | 12:00 PM
classciv's Avatar
Default Re: will these parts swap onto a 91 crx si (wood)
humm is there any way to modify themso they will work?
Old Mar 16, 2006 | 12:11 PM
FernEF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by si0385. &raquo;</TD></TR><TR><TD CLASS="quote">i remember reading a post a while back that said the 4 door hoods are different </TD></TR></TABLE>
yes ur correct on that
Old Mar 16, 2006 | 12:13 PM
FernEF's Avatar
as i know for sure anything that u want from a 4door wont fit, i know that the headlights are the same size but i remeber reading something that in order 2 use them u have to change the brakets.. correct if i am wrong
Old Mar 16, 2006 | 12:16 PM
classciv's Avatar
Default Re: will these parts swap onto a 91 crx si (FernEF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FernEF &raquo;</TD></TR><TR><TD CLASS="quote">as i know for sure anything that u want from a 4door wont fit, i know that the headlights are the same size but i remeber reading something that in order 2 use them u have to change the brakets.. correct if i am wrong</TD></TR></TABLE>
humm makes sence if the hood and fenders are different what about a hood off a civic hatch or does it have to be from a crx?
Old Mar 16, 2006 | 12:26 PM
JohnnieChimpo's Avatar
http://slhondaparts.com/browse.asp
Go here, check to see if the part numbers are the same.
Make sure you check all the years too since most parts are 88 only, 89 only and 90+91 same.
Old Mar 16, 2006 | 12:31 PM
FernEF's Avatar
good question.. i dont see y it shouldnt work wit a civic hood on a crx. i mean pretty much a crx and civic's have somewhat of the same front end.. if possible u may have a lil off set but i dont think nothing noticable
GPC91
Apr 12, 2012 08:47 PM
kilgoretrout
Sep 2, 2011 10:52 AM
Youlose1305
May 3, 2006 05:02 PM
c for sea
Oct 24, 2004 06:25 AM
