Rubbing with Azenis
Old Mar 14, 2006 | 10:33 AM
litterbox's Avatar
I am a (Trial User) Army
Default Rubbing with Azenis
Wow, haven't posted here in a while.
Ok here's the story. My car was sitting in the garage since october 05 until yesterday. I got some new tires (205-50-15 azenis) and new suspension (GC/Koni/GC Tophats) now I installed it all and lowered the car. I've got about 3 finger gap in the front and it's still kinda rubbing when I turn. I haven't even lowered the car to the desired ride height yet.
What can I do?
Old Mar 14, 2006 | 10:38 AM
EG93si's Avatar
Default Re: Rubbing with Azenis (litterbox)
what kind of car, do u know where its rubbing? what rims (offset)? can you see where on the tire its rubbing? just turning or all the time? just need some infor
Old Mar 14, 2006 | 10:40 AM
litterbox's Avatar
Default Re: Rubbing with Azenis (EG93si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG93si &raquo;</TD></TR><TR><TD CLASS="quote">what kind of car, do u know where its rubbing? what rims (offset)? can you see where on the tire its rubbing? just turning or all the time? just need some infor </TD></TR></TABLE>
Haven't examined where it's actgually rubing yet. It's only up front though. It might just be on the fender liner but I doubt it.
I've got an EH2 with a heavy k24.
Rims are stanard rotas. I bought em used but if I remember they are +40mm.
Old Mar 14, 2006 | 10:52 AM
EG6_GUY's Avatar
litterbox,
if you want to use those tires and get the car lower, you need different wheels. Either Honda wheels (Si, GSR, etc.) or step up to some less universal wheels. You need 15x6 or 6.5 w/ 45mm offset. 15x7 is tough to run at 40mm.
Old Mar 14, 2006 | 10:53 AM
litterbox's Avatar
Default Re: Rubbing with Azenis (EG6_GUY)
I think these are 15x6.5 though. Does rota make 15x6.5 +40mm, or am I confused?
Old Mar 14, 2006 | 10:58 AM
EG6_GUY's Avatar
I've seen them a few different offsets at 6", 6.5" and 7" from different suppliers. Every mm counts. The wider the wheel, the more offset is required to help reduce rubbing.
15x6 w/ an offset of 45mm will put the wheel in as far as possible.
Old Mar 14, 2006 | 11:00 AM
litterbox's Avatar
K thanks.
Old Mar 14, 2006 | 11:03 AM
EG6_GUY's Avatar
A lot of your posts have helped me. Glad I can reciprocate.
Old Mar 14, 2006 | 11:04 AM
EK79's Avatar
i had the same problems go with a 195 series tire feels the same
Old Mar 14, 2006 | 11:06 AM
litterbox's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG6_GUY &raquo;</TD></TR><TR><TD CLASS="quote">A lot of your posts have helped me. Glad I can reciprocate.</TD></TR></TABLE>
Old Mar 14, 2006 | 11:08 AM
Voyage34's Avatar
the azenis are also wider than most 205 tires, so that may contribute to the problem as well. ive seen both 211 and 217 (not sure which is accurate) measured in wheel/tire
there is more discussion of that in https://honda-tech.com/zerothread?id=1547403
Old Mar 14, 2006 | 11:09 AM
litterbox's Avatar
Default Re: Rubbing with Azenis (Voyage34)
Yeah the sidewalls are really ******* wide. It's a great tire. I actually get traction in 2nd, lol. On the way home from work tonight I'll stiffen up the struts and see if that helps a little.
oem_CD5
Aug 31, 2007 04:45 PM
soon2bdropped
May 13, 2007 08:37 PM
hypeR_ash
Mar 21, 2007 07:44 PM
hbsir888
Sep 30, 2006 01:52 AM
E Swift
Aug 23, 2003 08:20 PM
