How does this setup look to you turbo buffs?
I'm considering buying a Turbo ITR, here are the specs, let me know if it seems like a reliable setup. I noticed it doesn't have a Walboro fuel pump. Would I need one? By the way this is tuned w/ hondata 280whp @ 10psi. Sound good?
• Rev Hard Turbo Kit:
o Precision T3/04e Turbo
o Spearco Front Mount Intercooler
o Tial Wastegate
o Vortech Blow Off Valve
o Rev Hard Cast Iron Manifold
o 2.5” Downpipe
o 2.25" Aluminized Mandrel Bent Piping
• Thermal 3” Exhaust
• High Flow Catalytic Converter
• Precision 580cc Injectors
• AEM Fuel Rail
• AEM Fuel Pressure Regulator
• Turbo Smart Dual Stage Manual Boost Controller
• Greddy Turbo Timer
• Hondata s200b With hondata Base unit (not an aftermarket conversion harness)
• Clutchmasters Stage 3 Kelvar Clutch and Flywheel (They have less than 200 miles on them)
• Fal Slimline Fans
• Fuel Pressure Gauge
• Exhaust Temperature Gauge
• Boost Gauge
Edit - Pics of engine bay below, also of note, It still has A/C & Powersteering
Modified by soulrider4ever at 12:03 AM 3/15/2006
o Tial Wastegate
o 2.5” Downpipe
• AEM Fuel Rail
• Fal Slimline Fans
• Boost Gauge
I'd ask who tuned it... high compression ITR engine + 10 lbs requires a highly competent tuner. It seems like a well thought out setup.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soulrider4ever »</TD></TR><TR><TD CLASS="quote">Their's no replacement for good engineering
There's no replacement for correct use of "there"
</TD></TR></TABLE>There's no replacement for correct use of "there"
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackcivic44 »</TD></TR><TR><TD CLASS="quote">I'd ask who tuned it... high compression ITR engine + 10 lbs requires a highly competent tuner. It seems like a well thought out setup.
Owned
He said it was done at The Whip Factory near Chicago.
</TD></TR></TABLE>Owned
Yea, I spoke with Dave today. He said it does have a fuel pump, and from what he says, it was tuned extremly conserative.
Timing was 18 degrees, and he said he tuned it conservativly because it was his first b18c5 turbo tune.
Sounds to me like a solid setup
I like the setup except for the high flow cat, if You want to free up some power grab a test pipe and lose the high flow cat they do not last and for F.I who needs a cat,as far as tuning goes i would go to no one but evanstuning in P.A his work is flawless on anything ecspecially high compression type rs with turbos
Yea, I'll probably keep the CAT, plus I don't want the car to be so loud as to get me tickets everywhere. If it's too loud, I'd actually install stock cat/exhaust, I'd rather not get a ticket than 10 extra HP
Pic of engine bay (hows it look?)
Evo_Hustler
Feb 2, 2009 08:11 PM
POWERINTEGRA
Jan 20, 2006 07:09 AM
95si
Feb 2, 2003 04:23 AM
