B16a Y1 Tranny Guru Needed, have a few questions after swap.
Old Mar 14, 2006 | 04:37 AM
4thgenman's Avatar
Default B16a Y1 Tranny Guru Needed, have a few questions after swap.
Hello,
I recently swapped in a JDM B16a with Y1 cable tranny into my 91 4dr sedan. All went well except for the tranny won't shift. Before installing the engine, I replaced the flywheel with a 8lb one, and stage 2 clutch assembly with new throw out bearing.
Currently, the shift lever on the tranny will only move approx. 1 inch. No matter what type of clutch cable I get, it's too short. All clutch parts that went into this swap go to 90-91 integra. I think the throw out bearing is either binding or obstructed in some way. Anyways, I will have to drop the tranny to have a look
Has anyone ever seen a situation like this before? Clutch jobs are supposed to be easy. I've done many of these and never seen this situation before. Would appreciate if any cable tranny gurus could offer some input here...thanks.
__________________
My Mercedes Benz Projects
http://www.gempire.no-ip.com/my108
http://www.gempire.no-ip.com/my300e
My Honda 4th Gen Project
http://www.gempire.no-ip.com/myhonda4thgen/1.jpg
http://www.gempire.no-ip.com/myhonda4thgen/4.jpg
http://www.gempire.no-ip.com/myhonda4thgen/7.jpg
http://www.gempire.no-ip.com/myhonda4thgen/11.jpg
http://www.gempire.no-ip.com/myhonda4thgen/12.jpg
http://www.gempire.no-ip.com/m...3.jpg
My Ultima Online "Free" Game Server
Old Mar 14, 2006 | 05:27 AM
JDMCivicEF9's Avatar
Default Re: B16a Y1 Tranny Guru Needed, have a few questions after swap. (4thgenman)
Are you sure you got the clutch cable ajusted correctly? Try that first.
Old Mar 14, 2006 | 05:39 AM
4thgenman's Avatar
Default Re: B16a Y1 Tranny Guru Needed, have a few questions after swap. (JDMCivicEF9)
In order to make a clutch cable work on this tranny, had to put two hose clamps together so the cable end is attached to the tranny shift lever. However, in this case the tranny shift lever only moves about an 1inch, I'm beginning to suspect the throw out bearing is obstructed in some way.
Even if I purchased the wrong clutch parts, they naturally wouldn't bolt up to the b16a, correct?
Old Mar 14, 2006 | 04:53 PM
4thgenman's Avatar
Thankx a bunch,
Problem resolved.
Old Mar 14, 2006 | 06:09 PM
fourthgenhatchB17's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4thgenman &raquo;</TD></TR><TR><TD CLASS="quote">Thankx a bunch,
Problem resolved.
LOL, well post up what the problem was!!!
Old Mar 14, 2006 | 06:26 PM
4thgenman's Avatar
Default Re: B16a Y1 Tranny Guru Needed, have a few questions after swap. (fourthgenhatchB17)
No problem,
here is a link to another forum I posted the fix in.
http://www.clubcivic.com/board...28702
Old Mar 14, 2006 | 06:39 PM
What an interesting way of hooking up your clutch cable and a bit scarey. It shouldnt require any of that. I can change a clutch cable in about 3 minutes, lol. That should tell u how easy it SHOULD be.
Old Mar 15, 2006 | 04:17 AM
4thgenman's Avatar
I Agree with you. I've worked for Honda down in atlanta, GA. for a few years. We never came across any honda swaps though, only stock cars. Ofcourse we are talking about the higher class neighborhoods in that area, they don't mod thier cars like that. We did find alittle coke in the ash tray though a few times that's about it.
Anyways, don't actually know why stock clutch cables appear short on certain b16 swaps. I didn't take any short cuts and used better parts over stock. However, once the cable went on, there is free play like a normal cable, and i can adjust the plastic nut to get the right tightness. The clutch pedal feels smooth, and the car shifts fine now.
Old Mar 15, 2006 | 02:39 PM
Hmm i hear ya. I havent encountered a clutch cable issue yet in my time working with Hondas. The only thing i can think of is, compare the clutch cable bracket (thats mounted on the tranny) with one off a USDM 90-93 integra. I have a 92 YS1 (usdm) with a new Honda '89 civic cable. Works perfect.
tony7626
Feb 24, 2010 01:54 PM
teler86
Jan 24, 2006 06:30 PM
JDMracer17
Nov 9, 2005 08:33 PM
