jdm da9 guage cluster
Old Mar 14, 2006 | 03:20 AM
kennybintegra's Avatar
Default jdm da9 guage cluster
on the jdm gauge cluster, there are three warning lights to your right (when in drivers seat) top one is seat belt warning, the bottom one is for when the hatch opens, i dont know what the one in the middle is for, it has a funny looking symbol on it, like a wire or hose with steam coming off it (bad description), well i got a pic but i dont know how to post it, help me with that too please
Old Mar 14, 2006 | 05:52 AM
92whtgsr's Avatar
Default Re: jdm da9 guage cluster (kennybintegra)
you need to get a photobucket account, and then use the link that says img
you talking about that one in the middle http://i15.photobucket.com/alb...3.jpg
Old Mar 14, 2006 | 05:59 AM
four1one
Guest
Posts: n/a
Default Re: jdm da9 guage cluster (92whtgsr)
Im guessing it means your ***** overheating
Old Mar 14, 2006 | 06:01 AM
carchitect's Avatar
That is for the radiator. The light comes on when the coolant temp switch on the radiator is higher than normal and the cooling fan control unit will operate the fans for upto 15min after engine shutoff or until the engine fan switch opens. This is located on the back of the engine block to the left of the oil pressure switch on the 90-91 or on the thermostat housing for the 92-93.
Joe
Old Mar 14, 2006 | 08:00 AM
tegG2's Avatar
Default Re: jdm da9 guage cluster (four1one)
Crap, I always thought that meant steaming hot apple pie.
Old Mar 14, 2006 | 09:30 AM
LoseRPunKx182's Avatar
Default Re: jdm da9 guage cluster (tegG2)
mmm...like warm apple pie
Old Mar 14, 2006 | 12:37 PM
PyeeK's Avatar
Default Re: jdm da9 guage cluster (LoseRPunKx182)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LoseRPunKx182 &raquo;</TD></TR><TR><TD CLASS="quote">mmm...like warm apple pie</TD></TR></TABLE> hahah
Old Mar 14, 2006 | 08:08 PM
Default Re: (carchitect)
the car is not over haeting its running perfectly, that light is on though, the guy i bought the car off said that he had the radiator replaced not too long ago and the car was parked for a while, i've done all the minor fixes to the car as in hoses, fluids, tune-up, just have had the light come on, but ill' look into that this weekend, thanks for your help!
Old Mar 14, 2006 | 08:31 PM
teggy182's Avatar
Default Re: (kennybintegra)
does the usdm version have that light on it?
Old Mar 14, 2006 | 08:40 PM
Reid's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carchitect &raquo;</TD></TR><TR><TD CLASS="quote">That is for the radiator. The light comes on when the coolant temp switch on the radiator is higher than normal and the cooling fan control unit will operate the fans for upto 15min after engine shutoff or until the engine fan switch opens. This is located on the back of the engine block to the left of the oil pressure switch on the 90-91 or on the thermostat housing for the 92-93.
Joe</TD></TR></TABLE>
Wrong, wrong, wrong. Please don't post if you don't know what you're talking about.
The light in question is a warning light to tell you if the cat is overheated. That's all it is.
Old Mar 14, 2006 | 09:02 PM
four1one
Guest
Posts: n/a
Default Re: (teggy182)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teggy182 &raquo;</TD></TR><TR><TD CLASS="quote">does the usdm version have that light on it?</TD></TR></TABLE>
it doesnt so thats probably why its on...
Old Mar 14, 2006 | 09:54 PM
Sleepy_Red_hatch's Avatar
Default Re: (Reid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reid &raquo;</TD></TR><TR><TD CLASS="quote">
The light in question is a warning light to tell you if the cat is overheated. That's all it is.</TD></TR></TABLE>
this is correct...i cant remember if its 96-spec or 98-spec but one of the JDM ITR clusters had this light aswell.
Old Mar 15, 2006 | 09:30 AM
JETSPD1477's Avatar
Default Re: (Sleepy_Red_hatch)
take the bulb out. nobody likes the BBQ light.
Old Mar 15, 2006 | 10:07 AM
DA6mike's Avatar
Default Re: (JETSPD1477)
its for catalic conv.
Old Mar 15, 2006 | 10:10 AM
DA6mike's Avatar
Default Re: (DA6mike)
i took out my cat and since then light is on
Old Mar 15, 2006 | 10:12 AM
DA6mike's Avatar
Old Mar 15, 2006 | 10:15 AM
RaceCarRyne's Avatar
yep that light is def for the cat..
Old Mar 16, 2006 | 07:54 PM
Default Re: (DC2jdmIntegra)
im not saying that you guys are wrong but are you positive that this is correct, im ordering a new cat for her so please let me know if this is correct, and thanks alot for your feedback!
Old Mar 16, 2006 | 08:23 PM
Dee's Avatar
Dee
It's the cat heat sensor. It will light up if you remove the cat or if the cat is blocked.
Old Mar 16, 2006 | 08:34 PM
Spectrum24x's Avatar
Default Re: (Dee)
I wouldnt trust it as to say you need a new cat, b/c you dont have all the sensors for this correct?
I know a guy that had his seatbelts unplugged and that light was coming on (just an example of how the light can just be faulty)
Old Mar 16, 2006 | 08:49 PM
Default Re: (Spectrum24x)
all my sensors are working fine, everything works, that light is on though, i looked underneath the car at the piping, which is all new except for the cat i believe
Old Mar 17, 2006 | 09:05 AM
i need this light off badly, got inspection coming up soon, i was told two different answers about it, one for the cooling fan switch and the other for the cat, i looked under my car(lowered 2 inches) didnt see much but i didnt see a 02 sensor on cat, theres one in front of the cat on header it looks like, im gonna replace all my o2 sensors, and if that doesnt work im gonna replace my thermostat fan switch. but has anyone other than myself experienced this light coming on in their da wit jdm gauge cluster, if so what did you do to correct the problem? please help me out
Old Mar 17, 2006 | 09:15 AM
JETSPD1477's Avatar
USDM integras are not equipped with a cat temp sensor. there is nothing you can do about that light unless you take the bulb out or wire in a sensor.
Old Mar 17, 2006 | 09:23 AM
Modest Mouse's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JETSPD1477 &raquo;</TD></TR><TR><TD CLASS="quote">take the bulb out. nobody likes the BBQ light.</TD></TR></TABLE>
This man dosn't lie.
b18Aaron
86
May 8, 2010 10:03 PM
AK77
Sep 15, 2009 01:28 PM
crawlin
Feb 29, 2008 06:29 PM
Fighterinsnatch
Jul 20, 2007 01:27 PM
HondaHemi
Apr 30, 2006 10:49 PM
