need to put sum power in mah accord
Old Mar 14, 2006 | 03:17 AM
Adie's Avatar
Default need to put sum power in mah accord
I have an accord 01 ex i-4 .. i wanna put some more hp on it
what are the basics i gotta do for it ... im really a noob.. so if anyone wanna help me out thank you so much greatly appreciated and yea 1 more question will chipping in an ecu puts out better performance on mah car...
Old Mar 14, 2006 | 05:41 AM
HandoEX's Avatar
Default Re: need to put sum power in mah accord (Adie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Adie &raquo;</TD></TR><TR><TD CLASS="quote">I have an accord 01 ex i-4 .. i wanna put some more hp on it
what are the basics i gotta do for it ... im really a noob.. so if anyone wanna help me out thank you so much greatly appreciated and yea 1 more question will chipping in an ecu puts out better performance on mah car...</TD></TR></TABLE>
It all depends on what you want the car to do and what your budget is. The first performance upgrade I would recommend is a set of coilovers. A decent suspension set up will make the car much more enjoyable. If you just want to go faster, the most viable options are
1) turbo
2) nitrous
3) H22 engine swap
Bolt ons like intake, header, exhaust, pulleys will not yeild much for results. Chips are usually a complete waste of money. Good luck!
Old Mar 14, 2006 | 05:55 AM
Heat's Avatar
Just keep in mind that it is an Accord, not a Mustang or a 'Vette.
Old Mar 14, 2006 | 07:02 AM
FallenAngelHIM's Avatar
my advice, save up about $4000 then come back and ask the same question.
Old Mar 14, 2006 | 07:21 AM
accrd18's Avatar
Default Re: (FallenAngelHIM)
since ur a noob well let it go but let the search button on here be your bestest friend. good luck as well. but like HandoEX
said h22 swap or turbo (again ull find tons of results using search)
Old Mar 14, 2006 | 02:04 PM
cdsquad.net's Avatar
Default Re: (drivinaway367)
Quick word of advice that will get you far on this board.... Either learn correct english or just take the time to enter your text in correct english. It gets kinda old sitting around here reading other users "Engrish" all day long.
Old Mar 14, 2006 | 06:15 PM
Adie's Avatar
Default Re: need to put sum power in mah accord (HandoEX)
okie thanks alot well i was thinkin about putting in an intakes first engine swaping and turbo is too expensive for me as of now that ll take me a while til i would be able to get thanks guys and yup i just want to make the car go faster mostly but thanks for your suggestion
Old Mar 14, 2006 | 06:55 PM
wingback44's Avatar
id go with suspension first, but if you are just looking for more power there are a couple of things you can do with out shelling out big bucks for a turbo or engine swap. intake/header/exhaust is the most basic. pulley kit might yeild a few horsepwer. if you are looking for a more serious gain than bolt ons, i would say find a new cam for your car, find a shop to port and polish the head, and get a bored out intake manifold and throttle body.
Old Mar 15, 2006 | 12:37 AM
'00Accordster's Avatar
Default Re: need to put sum power in mah accord (Heat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Heat &raquo;</TD></TR><TR><TD CLASS="quote">Just keep in mind that it is an Accord, not a Mustang or a 'Vette. </TD></TR></TABLE>
Thank god its not a mustang. It's certainly not a corvette
Old Mar 15, 2006 | 02:55 AM
YeuEmMaiMai's Avatar
jooo needz to mack daddy on the searchz buttenz homie. there be a whole schnizzle of 'fomation goinz onz....
see that there search button? it's red, use it.
Old Mar 15, 2006 | 05:10 AM
Eagle16nam's Avatar
Default Re: (YeuEmMaiMai)
what about F20B thats a great alternative to an H22
Old Mar 17, 2006 | 01:48 AM
Default Re: (Eagle16nam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Adie &raquo;</TD></TR><TR><TD CLASS="quote">okie thanks alot well i was thinkin about putting in an intakes first engine swaping and turbo is too expensive for me as of now that ll take me a while til i would be able to get thanks guys and yup i just want to make the car go faster mostly but thanks for your suggestion</TD></TR></TABLE>
Guess they don't teach punctuation any more either
krytoi
Mar 19, 2007 01:22 PM
CaldoR
Jul 15, 2005 07:55 PM
hotNsexy69
Acura TL, RL & ZDX
47
Jun 2, 2005 09:49 PM
KRiS1
Dec 9, 2003 06:19 PM
