speed sensor
Old Mar 13, 2006 | 11:10 PM
k7q's Avatar
k7q
Default speed sensor
i searched. where is the speed sensor on my crx located at? my speedometer is not working.
Old Mar 14, 2006 | 10:37 AM
k7q's Avatar
k7q
Default Re: speed sensor (k7q)
anyone got a pic of where my speed sensor is located at?
Old Mar 14, 2006 | 10:59 AM
ImprtTuner88's Avatar
its not a speed sensor in a crx, it is a bad speedo cable. If it is a stock cluster in your Rex it has a cable....................................and yes the cables do go bad.
Old Mar 14, 2006 | 02:09 PM
k7q's Avatar
k7q
Default Re: speed sensor (ImprtTuner88)
hmm. ok thanks for the info
Old Mar 14, 2006 | 02:25 PM
RCautoworks's Avatar
Check by the back of the trans, they do pop out sometimes. Also its the big round clip on the back of the cluster, make sure its popped in.
Old Mar 14, 2006 | 02:41 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
pics here:
https://honda-tech.com/zerothread?id=1325930
Old Mar 14, 2006 | 07:21 PM
k7q's Avatar
k7q
Default Re: speed sensor (88DXCRX)
cool even more help. will check on it tomorrow. day off.
thanks
Old Mar 15, 2006 | 11:16 AM
k7q's Avatar
k7q
damn the cable is broken and the end of it is stuck in there? how do i take the whole thing out?
Old Mar 15, 2006 | 11:19 AM
yellowrexsi's Avatar
Gotta pull the gauge cluster out and slide it through the firewall. Its not that hard.
Old Mar 15, 2006 | 11:21 AM
k7q's Avatar
k7q
Default Re: speed sensor (yellowrexsi)
how do i remove that?
Old Mar 15, 2006 | 11:31 AM
The clip in the center of the brass slides out. Then it should pull apart. I have never seen one that messed up. The guts of the tranny are on it
Old Mar 20, 2006 | 05:33 PM
k7q's Avatar
k7q
im gonna go to te junk yard soon. what car uses a cable for the speedometer instead of a crx.
Old Mar 20, 2006 | 07:45 PM
user 72830283's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k7q &raquo;</TD></TR><TR><TD CLASS="quote">im gonna go to te junk yard soon. what car uses a cable for the speedometer instead of a crx.</TD></TR></TABLE>
i may be wrong when i say this but the electronics VSS's started showing up when cars went obd-1, i could be wrong when i say this..but i'm gonna guess the older integras 86-89's had the cable driven VSS...the EF crx/civic had a cable driven VSS for sure and the civic cable vss shouldnt be hard to get a hold of..
Modified by pr3d at 4:57 AM 3/21/2006
Old Mar 23, 2006 | 09:32 AM
k7q's Avatar
k7q
Default Re: speed sensor (pr3d)
are hf and si speedometer cable the same?
Old Mar 23, 2006 | 09:35 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k7q &raquo;</TD></TR><TR><TD CLASS="quote">are hf and si speedometer cable the same?</TD></TR></TABLE>
should be, i dont see a reason to change it.
Old Mar 23, 2006 | 11:00 AM
headhunter's Avatar
i ran into this same problem last night. my speedo cable snapped inside the hole where you insert the cable. there was a little stub that you could barely see while shining a flashlight down the hole. what i did to grab it was use a small rubber tube with a diameter small enought to fit it snug and then i yanked it out careful. hope this helps. i didnt' have to remove the whole speedo gear assembly, my cable just snapped.
Old Mar 23, 2006 | 05:01 PM
k7q's Avatar
k7q
Default Re: (headhunter)
OMG!! when i was replacing the cable a piece of it broke inside, so i tried to pull out the cable from the cluster and pulled it out but there is still a piece of cable stuck inside. is there a way i can get it out?
i tried to use to new cable and push it out but no luck. -_-
Modified by k7q at 9:48 PM 3/23/2006
Old Mar 24, 2006 | 04:21 PM
k7q's Avatar
k7q
Default Re: (k7q)
ok i fixed it.
another question. my check engine lights goes on after i drive for about 15 mins. and if i turn off car and then start it again it goes away and 10-15 mins later it comes back. help?
Old Mar 25, 2006 | 04:44 PM
Default Re: (k7q)
what code is it throwing
cmkwood
Mar 24, 2013 10:49 AM
Channooo
Aug 12, 2009 01:50 PM
ugly rex
Jan 1, 2007 11:19 PM
LAWST
Mar 3, 2005 06:51 PM
slow4dr
Dec 27, 2004 07:19 AM
