Crx exhaust fits Civic HB??
Old Mar 13, 2006 | 09:44 PM
T3k C's Avatar
Default Crx exhaust fits Civic HB??
Would it fit?
Old Mar 13, 2006 | 09:47 PM
crxnj's Avatar
Default Re: Crx exhaust fits Civic HB?? (B16DSEF)
The axle-back is the same,,But the B-pipe of the crx is a tad bit shorter,,I forget the exact number,,I think between 4-6 inches ?
Old Mar 13, 2006 | 09:51 PM
T3k C's Avatar
I'm in need of an exhaust badly and I came across a cheap crx exhaust. So I guess it won't bolt right in.
Old Mar 13, 2006 | 09:56 PM
crxnj's Avatar
Default Re: (B16DSEF)
Yeah it will bolt on,,But there will be a gap between the midpipe and the axle back section..So you have to add a little section
Old Mar 14, 2006 | 07:06 AM
T3k C's Avatar
Can i customize it with some exhaust parts from a local vatozone?
Old Mar 14, 2006 | 07:09 AM
ludesrv's Avatar
If you can weld you cut the B pipe and add a few inches, 5-6 I thought it was. Then it will bolt up.
Old Mar 14, 2006 | 08:09 AM
65stang90crx's Avatar
Default Re: (ludesrv)
Without welding he should be able to buy an intermediate pipe from a tuffy or something shouldnt he? Like a gap filler pipe for removing mufflers cattys and stuff.
Old Mar 14, 2006 | 09:28 AM
Mugencrxsir1's Avatar
Default Re: (65stang90crx)
yep, it's 6" shorter, just extent the b-pipe.
Old Mar 14, 2006 | 10:00 AM
beyondspexj's Avatar
yea just grab 2 exhaust clamps, pb blaster( for lube ) and about 6 inches worth of pipe and your in there!
v0od0o
Nov 17, 2009 09:23 PM
95LStizzy
Aug 8, 2006 05:11 AM
srv3fender
Mar 25, 2005 10:04 AM
SIC CRX
Feb 25, 2005 10:17 AM
goofball123321
Jan 24, 2004 08:47 PM
