tdc sensor------->please help
Old Mar 13, 2006 | 09:17 PM
mikezcdx's Avatar
Default tdc sensor------->please help
Is the tdc sensor the same as the crank angle sensor? and if so, could a bad tdc/crankangle sensor make the ecu go into limp mode? and to make sure im correct, limp mode is when the car wont rev past 3200 rpm, and a complete loss of power?
i have also bought a new dizzy, and still the same problem. also car started running severly retarded. also changed the o2 sensor. same problem. could it be the wiring? just swapped a sohc zc into the 91 dx. loved it until this happened. Any input would be priceless. please help.
mike
Old Mar 17, 2006 | 06:09 PM
mikezcdx's Avatar
Default Re: tdc sensor------->please help (mikezcdx)
bump................................
Old Mar 17, 2006 | 09:43 PM
Rukusmasta2's Avatar
First make sure its on timing check and double check timing the check, and double check ur wiring
Old Mar 18, 2006 | 05:39 AM
uglyrex's Avatar
Default Re: tdc sensor------->please help (Rukusmasta2)
tdc senso on a different plane on same shaft look at the pics are of a obd1 dizzy but pretty much the same
and yes double check wiring you need to add two wires from dizzy when doing dx swap as dx is a sloppy car when talking about its fuel management
Brandtb
Nov 10, 2015 03:18 PM
Godspeedmj
21
Oct 27, 2010 10:30 AM
crave13k
Honda S2000
Jan 21, 2009 09:57 AM
Schaz
May 4, 2005 11:31 AM
bigblu333
Jan 5, 2004 03:48 PM
