valve adjustment
ok i have a 2000 honda accord ex v6.it makes a ticking sound.well my question is.can this cars have the valves adjusted?? someone told me that v6 dont need tohave the valves adjusted.please get back
All Honda V6 engines thru 2002 use mechanical cam followers which require periodic adjustment for quite operation.
The specifications are as follows:
Intake Values: .008 to .009"
Exhaust Valves: .011 to .013"
Refer to your Helm, Chiltons or Hanes Shop Manual for the correct proceedure.
(You do own one, RIGHT?)
P
P
a valve adjustment isn't hard. You only need a few tools to complete the job. It's mostly about feel. After the first set of valves, you should be getting the hang of it. Just follow the directions in your shop manual and you shouldn't have any problems.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Group A »</TD></TR><TR><TD CLASS="quote">i have a 95 LX and im due for a valve adjustment...how hard is this? im fairly experianced with working on cars...i've done all the basic stuff(brakes, fluid drain and fill, etc.), and several suspension installs(spring/shocks,control arms, etc.)...do u think this will be something i will be able to handle without ******* shyt up?</TD></TR></TABLE>
http://www.ozaccord.com/forums/showthread.php?t=27
step by step instruction
As Honda-Master offered:
It is not difficult. Time consuming and detail intensive yes, but not difficult. With the proper tools, a bright and moderate Saturday before you and a ready supply of liquid fortitude available; it may not only be an enjoyable effort but also one forgotten (depending on how much "fortitude' you consume).
Take your time, have the GF or Significant Other check up on you occasionally and you'll be done in no time (almost)
P
P
tommyleeruiz
Jul 29, 2008 06:57 PM
