aftermarket fog lights wired to stock lights help
Old Mar 13, 2006 | 08:35 PM
sony224422's Avatar
Default aftermarket fog lights wired to stock lights help
i installed aftermarket fog lights, and they come with a switch that you turn on and off yourself, its quite annoying, so i was wondering if its possible to somehow wire them into the stock lights so they turn on with them? I don't care if they turn off with the highbeams on like they are supposed to.. i just want them to turn on with the stock lights.
Thanks.
Old Mar 13, 2006 | 09:16 PM
concept11253's Avatar
Default Re: aftermarket fog lights wired to stock lights help (sony224422)
Yes, in your fuse box, use wire taps to wire into the switch for your headlights.
Old Mar 13, 2006 | 11:50 PM
sony224422's Avatar
Default Re: aftermarket fog lights wired to stock lights help (concept11253)
where can i get fuse taps, and im assuming i go into the one thats for the headlights?
Old Mar 14, 2006 | 03:03 AM
georgeda's Avatar
Instead of putting more load on the headlight switch, it would be better to use a relays for each fog light. They can be wired under the hood to the low beam bulb wires.
Modified by georgeda at 1:52 PM 3/14/2006
Old Mar 14, 2006 | 07:32 AM
sony224422's Avatar
Default Re: aftermarket fog lights wired to stock lights help (georgeda)
thats what i was thinking.. the fog lights are 55 watts. do i need a seperate relay for each one?
Old Mar 14, 2006 | 10:04 AM
georgeda's Avatar
Here is everything you ever wanted to know about relays:
http://www.classictruckshop.co...o.htm
Look at BOSH RELAY EXPLAINED and WIRING YOUR FOGLIGHTS.
Instead of using the dash switch you can connect to the low beam wires for power.
Old Mar 14, 2006 | 10:24 AM
sony224422's Avatar
http://www.classictruckshop.co...s.htm
i looked at that, and it tells me to use a relay, but won't that mean i'll still need to use the switch? My goal is not have to worry about the fog lights being on when the car is off..even if i have to keep them on the switch they are on now. I can easily hide the switch and leave it on all the time, but when the car is off, i want them to be off without me having to do anything.
JoseCuervo
Lighting
Feb 28, 2012 04:38 PM
SoL_ger
Mar 14, 2010 11:07 AM
j.packsb
Mar 2, 2010 05:54 AM
Whatislove
Honda Civic (2001 - 2005)
Nov 27, 2008 10:13 PM
4DRmafia
Jul 12, 2004 10:51 PM
