Where to find Beaks kit? (Itr rear sway/ with brackets for a 92hatch )
Old Apr 1, 2002 | 10:24 AM
SpoonSportsFanatic's Avatar
Default Where to find Beaks kit? (Itr rear sway/ with brackets for a 92hatch )
I have heard good things about Beaks kit for an Itr sway install on an EG hatch 92' . I already have gsr lCA's . My question is wh4er to find a great price on the kit ? whats this guys web site?
Old Apr 1, 2002 | 10:34 AM
tampaSi's Avatar
New User
Default Re: Where to find Beaks kit? (92dxHatch4Jerry)
geocities.com/beaksproducts i believe
Old Apr 1, 2002 | 12:17 PM
LostGsr's Avatar
Beaks Kit : http://beaksproducts.com/main.html
Bsq Kit: http://geocities.com/bretq/swaybar_install.html
Both are great kits!
Old Apr 2, 2002 | 10:09 AM
dilow's Avatar
New User
Default Re: Where to find Beaks kit? (LostGsr)
This sounds interesting...
Would I need this kit: http://www.beaksproducts.com/srk-eg.html
if I were to pick up an aftermarket rear sway bar for my 95 EX coupe? Or is it just for peace of mind that you won't mess up your car? I know that I don't have a rear sway, so I'm not sure if I should be getting this kit, since it might not be built to have a sway...
Old Apr 2, 2002 | 02:13 PM
mercury's Avatar
New User
Default Re: Where to find Beaks kit? (dilow)
Hey fancy seeing you here, G. So to answer your question, yes, you'll need either the Beak's or the BSQ kit to reinforce your subframe because without it, the ITR bar WILL rip the brackets right off. You'll also need the lower control arms from an Integra to bolt the endlinks onto. It turns into quite a project on the '92-95 Civics because of all the little bits and pieces you need.
The next time we run into each other, I can go over everything with you.
Old Apr 2, 2002 | 02:51 PM
dilow's Avatar
New User
Default Re: Where to find Beaks kit? (mercury)
Hey J,
Didn't know you were on these boards... anyway, I was planning to get an aftermarket rear sway for my car. Not the itr. Is the kit still needed?
Old Apr 2, 2002 | 06:23 PM
mercury's Avatar
New User
Which bar were you planning on getting? The thicker the better. I don't know of any aftermarket bar that's thicker than the ITR, besides Mugen.
Kev95lx
Sep 26, 2003 05:54 AM
Daysleeper
Feb 20, 2003 01:52 PM
J.P. 4rm The dPk*
Nov 18, 2002 10:58 AM
Guam_CiviC619
Sep 16, 2002 05:24 PM
KRiS1
May 20, 2002 04:21 PM
