seized bolt (that one bolt that connects the shock to the rear LCA)
Old Mar 13, 2006 | 08:04 PM
magicaltrout's Avatar
Default seized bolt (that one bolt that connects the shock to the rear LCA)
600 pounds of torque, wd40, broke a wrench, broke a craftsman socket: nothing.
i dont want to resort to this:
http://www.team-integra.net/se...=1025
so i'm asking you guys to see if any of you have some super creative way (or chemicals to spray) to get this little bastard off. i'm borrowing an even more powerful impact gun later this week to see if that'll do.
Old Mar 13, 2006 | 08:13 PM
god.loves.ugly
Guest
Posts: n/a
Default Re: seized bolt (magicaltrout)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by magicaltrout &raquo;</TD></TR><TR><TD CLASS="quote">600 pounds of torque, wd40, broke a wrench, broke a craftsman socket: nothing.
so i'm asking you guys to see if any of you have some super creative way (or chemicals to spray) to get this little bastard off. i'm borrowing an even more powerful impact gun later this week to see if that'll do.</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=1558450
see that link. two in one night. ha ha ha. i feel your pain.
Old Mar 13, 2006 | 08:16 PM
rockdude14's Avatar
welcome to the club
basically
just cut the bolt
go to napa and get a bearing press tool (free to rent)
and put a new bushing in and use anti sieze
Old Mar 13, 2006 | 08:53 PM
97tegGS's Avatar
Also a Grade 5 or 8 3/8x16 x 1.5 with lock nuts and washer on the backside will work as well. That is what I had to do.
Old Mar 13, 2006 | 09:39 PM
dclsvtec's Avatar
use a heat wrench.... torch it and like break it loose. just dont burn yourself
Old Mar 13, 2006 | 09:42 PM
DC4me's Avatar
Default Re: seized bolt (dclsvtec)
cut the bolt off and buy new lcas so you won't have the pain of having to get the shot bushing out and pressing a new one in. just my.02 so gl because i had the same problem.
Old Mar 13, 2006 | 10:49 PM
Default Re: seized bolt (DC4me)
if i were to get new LCAs... what do you think about these?
http://www.hybrid.honda-perf.org/a0-sus.html
anyways, thanks for the suggestions... i'll try to heat it up a bit before going at it again the end of this week although i still wish there was something i could just soak the thing in for a day or two to loosen things up.
Old Mar 13, 2006 | 11:14 PM
aspec101's Avatar
Use the sawzall method I always plan ahead on all strut installs. The bushing is easy to replace. Don't was money on new lca's unless you want some fancy bling bling.
Old Mar 14, 2006 | 01:39 AM
It's*BOLO!!'s Avatar
Guess whos bizzack
Default Re: seized bolt (aspec101)
new LCA's FTW!!!!!
Old Mar 14, 2006 | 05:57 AM
92whtgsr's Avatar
Default Re: seized bolt (BOLO-FTW!!)
yah that bolt pretty much always breaks just cut that **** off and get new lca's
EK_B
27
Aug 14, 2007 08:36 PM
90IntegraGS1.8L
18
Apr 18, 2007 11:17 AM
jjaskula1
10
Nov 24, 2005 08:55 PM
dukers
Nov 14, 2004 12:36 AM
type Gendy
22
Apr 1, 2004 11:29 AM
