Can't find any OEM replacements for my JDM 1pc foglight bulbs for my DA
Old Mar 13, 2006 | 07:08 PM
da9pwnsu's Avatar
Default Can't find any OEM replacements for my JDM 1pc foglight bulbs for my DA
What i know:
I need two H3 bulbs that are either 35 or 55 watt, with a round connector (see pic..its the yellow thing)
Problem:
So ive only had my JDM 1pcs for 2 days and one of the oem foglights decide to go out on me.
ive looked everywhere now, and i cant find any replacements that use the round connector. I went to kragen, pep boys, and the Sylvania oem replacement 55 watt use a flat connector which wont fit
I know that i need either 35 or 55 watt H3 bulb and anything over that will melt the housings...let me know what u guys all use for replacement for your jspec headlights
Old Mar 13, 2006 | 07:12 PM
teggy182's Avatar
Default Re: Can't find any OEM replacements for my JDM 1pc foglight bulbs for my DA (oldschoolDA9)
you should try a local tuner shop insted of the big auto shops
Old Mar 13, 2006 | 08:07 PM
SlammedDC2teg's Avatar
Those are really easy to get in the bay area. Any real tuner shop should stock those.
Old Mar 13, 2006 | 08:35 PM
Desired_Speeds's Avatar
try vision motorsports, or whatever its called. Its on Noreiga and like 22-23 ovenue or somewhere around that.
Old Mar 13, 2006 | 09:02 PM
importdude2000's Avatar
i have tons....
let me know
i took em off jdm 1peices
Old Mar 13, 2006 | 10:01 PM
Nevets's Avatar
Default Re: (importdude2000)
I bought some cheap H3 bulbs from autozone just for the little conversion piece that came with it. They have it at autozone, or at least the ones around here do.
Old Mar 13, 2006 | 11:17 PM
da9pwnsu's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importdude2000 &raquo;</TD></TR><TR><TD CLASS="quote">i have tons....
let me know
i took em off jdm 1peices</TD></TR></TABLE>
pm'd!
Old Mar 15, 2006 | 02:59 AM
CJ_2Dr's Avatar
Default Re: (oldschoolDA9)
my friend had this problem aswell, the ones he bought had the flat connectors, they were Sylvania oem replacement 55 watt. what we did was on the side of the housing we cut the wire and cripped in a new connector and heat srinked it so now any bulb he buys will fit. and it was cheap and easy and it works like normal. try that if u dont want to cut it then idk u should be able to find the bulbs somewhere.
Old Mar 15, 2006 | 03:14 AM
integra3586's Avatar
Default Re: (redDCcoupe)
cant you just cut and splice a new connector on the ones from autozone?
Old Mar 15, 2006 | 04:28 AM
BlackLudeSi's Avatar
Default Re: (B18B-SC)
Just switch it to the right connection I got two on my car no problems
amej8
12
Jan 2, 2007 08:26 PM
winerep
19
Jun 16, 2006 02:21 PM
digitalh3lix
Dec 13, 2004 02:24 AM
Kicker773
Aug 7, 2004 09:36 AM
julow
Apr 4, 2004 03:06 PM
