map sensor code 5
Old Mar 13, 2006 | 06:34 PM
88crxdxfastwhip's Avatar
Default map sensor code 5
My ecu is throwing a coe 5.I just bought the car from a guy about a month ago and im getting around to working on it now.I knew somthing was wrong with it but i thought it just might need a tune up,I was wrong. looked at the ecu and im getting a 5 which is the map sensor looked under the hood and the hose's that run from the map sensor are disconnected and cut some hose's arent even there.I dont know where they are supposed to plug in so does anyone have pics or any help.The car runs fine except if you hit the gas real quick it sputters but if you slowly press it it runs pretty good.Any suggestions???? what does the map sensor do anyways.is there a way to cut it off or plug somthing?
Old Mar 13, 2006 | 06:35 PM
RCautoworks's Avatar
Default Re: map sensor code 5 (88crxdxfastwhip)
https://honda-tech.com/zerothread?id=1558301
92SikHatchBak
Engine Management and Tuning
Jan 6, 2010 09:38 PM
92ehatch
16
Feb 19, 2007 11:41 PM
Sci_v_icI
Apr 5, 2006 10:44 AM
