Where have you guys run your nitrous line?
Old Mar 13, 2006 | 06:24 PM
NitrousB.I.G.'s Avatar
Default Where have you guys run your nitrous line?
I am finishing up a new nitrous kit install in my EG and I'm trying to figure out a better place to run the nitrous line. I previously ran the line outside the car, down the side of the car inside those plastic moldings down the side of the car. But I dont want to do the same again because it left the line exposed behind the front tire. I am thinking of running it inside the car but I cant figure out how to get it through the fire wall without kinking the line. To further complicate things I have the Nitrous Express Race Line http://www.nitrousexpress.com/...e.pdf and aside from being bigger in diameter it doesnt bend as well as the regular stainless line. Any ideas would be great.
Old Mar 14, 2006 | 03:56 AM
BoredNStroked's Avatar
Go through one of the factory rubber grommets......or drill a hole and put your own grommet in. if your car didn't come with AC then go through where the lines are suppose to go.
Old Mar 14, 2006 | 04:28 AM
Fat Chandler's Avatar
Default Re: (BoredNStroked)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoredNStroked &raquo;</TD></TR><TR><TD CLASS="quote">Go through one of the factory rubber grommets......or drill a hole and put your own grommet in. if your car didn't come with AC then go through where the lines are suppose to go.</TD></TR></TABLE>what i did. Also i secured the line with tie down blocks so it woldnt move around, because when i just had it running across the floor, it kept pulling out the grommet and pissing me off.
Old Mar 15, 2006 | 10:15 PM
Default Re: (Fat Chandler)
I think I found a hole on the drivers side in front of the pedals, under the master cylinder.
Old Mar 20, 2006 | 08:33 PM
TeGGY_LS
Mar 19, 2005 08:21 PM
RTE117
25
Mar 20, 2004 12:54 PM
Broken Gearbox
Sep 9, 2003 04:17 PM
auto-gs-king
Feb 28, 2002 01:21 AM
