ECU codes, code , explanation
Old Mar 13, 2006 | 05:03 PM
RCautoworks's Avatar
Default ECU codes, code , explanation
For faq
White smoke out the exhaust, does not always mean a blown head gasket. Which some fools are to stupied as not to beleive it. However trying to convience them differently, is like telling somebody that something is hot and will burn them, yet they will still try to feel/pick-up it. It can be caused by the engine running a little to rich or from a bad sensor. One example is when running N2O, and the extra fuel that is added when it's been activated. N2O is odderless and coloress so it cannot be causing it. This is also a visual clue when someone is using it. When I had my supercharger installed, I was told that I should be seeing a little white smoke too when in boost. I also saw an HF with a bad dist., it had white smoke pouring out of the exhaust, until it was replaced. When adjusting the fuel pressure on mine, it to will have white smoke out the exhaust at idle, if it's set a little too high.
Code 1 - O2 Sensor - Code 2 is for the one down on the cat. Which was not used in the US.
MAP, TDC & CYL (along others) helps determine the Pulse Width (PW) in which fuel is injected. With the MAP having the most control, out of all other sensors.
Testing requires a voltmeter.
The voltage on a properly working sensor should sweep between .1 to .9 volts 2-3 times a second @ 2500 rpm. Peeps with A/F Ratio meters, will see the reading moving/dancing around all the time. This means everything is working all right
Unheated O2 sensor have to heat up, and maintain 600+ degrees F in order to work properly. Until that temp is reached, the ECU sends out .45V, until it reaches operating temp. When temp is reached, the O2 sensor will send out .5V. Telling the ECU it's up to operating temp, and can now go into "Closed Loop" operation. That is, if all the "other" conditions are met too, like water temp, etc....
Voltages:
Lean - .1 volts
stoich - .5 volts
Rich - .9 volts
O2 sensors do not wear out... they fail due to contamination.
Silcon Depostits (from using gasket sealents that are not O2 safe)
Solvents, Lubricants, Cleaners, Adhesives
Gasoline Additives
Lead
Carbon Deposits (rich condition)
Engine Oil (burning or spilling)
Anti-Freeze (blown head gasket)
Clogged External Air Vents (dirt, ect...)
Running Lean (too much heat)
ECU damage can occure using the wrong sensor, due to the execessive current draw requirements of non-stock sensor.
Back
Code 3 - MAP Sensor
Usually means there is something wrong with the sensor itself.
Has the the most control over the fuel injector pulse width.
When the MAP voltage is too high check code 5.
incorrect cam timming
incorrect iginition timming
restricted exhaust
excessively worn engine or leacking valves
Testing - Voltage varies from about .6v to 2.7v. Running no load will usually be less then 1v or slightly lower, when warm and idling. Under heavy load 2.5 to 2.75 volts. PA sensor should also read close to the same with Engine Off and Key On (EOKO).
Condidtion MAP Volts Inj PW Exhaust CO
Normal .94 2.0 ms .3%
Vacuum Leak Created on MAP Hose 1.13 2.3 ms 6.5%
Bigger Vacuum Leak Created on MAP Hose 1.25 2.7 ms 9.9%
MAP Sensor Wires:
1 White/Red
1 Green/White
1 White
Back
Code 4 - Crank Angle Sensor
Top sensor in the dist. and is used for fuel control and misfire detection.
If the dist. base bearing starts failing, it will start heating the sensor(s) up, destroying the magnetism causing a code(s). It will lose 10% of it's strenght, each time it is heated up, to a 170 degrees plus.
In most cases, replacing the distributor is the only alternative. Especially if the bearing has failed.
Honda does don't stock the bearing itself, but other after-market compaines are said to have one.
If you have problems starting the engine, or drivability after the install check your cam aligment. The seizing bearing might have caused it to jump a tooth/notch or two. From the extra drag due to the bearing failing.
Back
Code 5 - MAP Sensor
Usually means there is something wrong with the hose.
When the MAP voltage is too high (indicating vacuum is lower then normal) the problem is rarely a faulty sensor, but in fact a problem with the engine itself
restricted exhaust
Back
Code 6 - Coolant Temperature Sensor (ECT)
Helps determine the Pulse Width of the injectors at start-up. When this sensor starts acting-up, the engine will get hard to start, on "warm/hot starts". The wax pellet inside the sensor has gotton lazy. Sending bogus signals to the ECU, causing it to flood the engine.
When cold, it should read 2.5-4.5 volts. Also, check the IAT sensor for the same voltage, they should read close to the same. When full warmed should read .5-.6 volts. You can use a resistor with a 330 ohm 1/2 watt spec, or one from Radio Shack part# 271-1113. Start the engine and let it warm up, then kill the engine. Put the resistor in the wire connector on the harness. Start the engine, if problem goes away then replace the sensor. Use this only for temporay testing, it will cause other performance issues. Meaning the ECU will think the engine is always warmed up, when it's not.
This sensor is also known to cause hot and cold starting problems.
Temp F Volts
0 4.70
10 4.50
20 4.29
30 4.10
40 3.86
50 3.61
60 3.35
70 3.08
80 2.81
90 2.50
100 2.26
When the engine is hot, the sensor is telling the ECU that the engine is cold. Flooding occurs, due too a improper injector pulse width. Unplug the sensor if you need to start the car in a hurry. The ECU will throw a code and go into limp mode, however you will be able to drive it.
Back
Code 7 - Throttle Position/Angle Sensor
TPS sensor input is used to determine when the throttle is:
Idle
Wide Open Throttle (WOT)
Rapid Movement
During these conditions the ECU makes changes to the injector Pulse Width (PW).
The PW is widen slightly when the throttle initially goes to idle. Within a few seconds the O2 sensor will correct the mixture.
Closed Throttle Input (under .5V), engine RPM is above 1100, engine is warm. The fuel injectors will be shut-off (used to conserve fuel). Peeps with A/F Ratio Meters will see this happen, when the gauge drops to full lean, or no reading at all.
When Wide Open Throttle is detected the PW is increased above normal fuel delivery. This is also known as "Open Loop" operation, when the ECU ignores the output from the O2 sensor.
With Rapid Throttle Opening the ECU is watching the TPS input voltage for rapid changes. A sudden rise in the voltage would mean the throttle was opened quickly. So the ECU would increase the PW momentarily. As soon as the MAP sensor senses the drop in vacuum, it will take over.
Testing - With the Key On, Engine Off hook up a voltmeter to the TPS. @ idle (closed throttle), voltage should be close to .5V and @ WOT (Wide Open Throttle) voltage should be 4.5V.
The best way to adjust the TPS voltage is @ idle (closed throttle). While Key On, Engine Off, hook up voltmeter between the yel/wht & grn/wht and observe reading. If it needs to be adjusted, loosen the TPS mounting and move the TPS until voltmeter reads close to .5V. The check engine light will let you know immediately whether you missed up or not.
TPS Sensor Wires:
1 Red/Blue
1 Green/White
1 Yellow/White
Back
Code 8 - Top Dead Center Sensor
It's the second sensor in the dist. It can also be located on the camshaft of DOHC engines. It determines the injection timming for each cylinder, also used to detect engine speed (rpm) to read the basic discharge duration, for different operating conditions.
If the dist. base bearing starts failing, it will heat the sensor(s) up, destroying the magnetism thus causing a code(s). It will lose 10% of it's strenght, each time it is heated up, to a 170 degrees plus.
Honda does don't stock the bearing, but other after-market compaines are said to have one.
Back
Code 9 - No. 1 Cylinder Position Sensor
It's the third sensor in the dist., and it detects the position of the No. 1 Cylinder, as the base for the Sequential Injection. It can also be located on the camshaft of DOHC engines.
CYP sensor is mounted on the exhaust cam on the ZC.
If the dist. base bearing starts failing, it will heat the sensor(s) up, destroying the magnetism thus causing a code(s). It will lose 10% of it's strenght, each time it is heated up to 170 degrees plus.
Honda does don't stock the bearing by itself, but other after-market compaines are said to have one.
Back
Code 10 - Intake Air Temperature Sensor
When cold, it should read 2.5-4.5 volts. Also, check the ECT sensor for the same voltage, they should read close to the same. Use the above chart for the ECT for checking voltage, since the two sensor should read close to the same.
IAT Sensor Wires:
1 Red/Yellow
1 Green/White
Back
Code 12 - Exhaust Gas Recirculation System
Mounted on the right back corner of the fire wall. It cannot be purchased seperatly, but only as a unit. Voltage range of the lift sensor is 1.2v closed to 4.0v open. It was required on all cars sold in in CA. starting in 1988. However, some CIVIC's were engineered without having to use one, to control NOx.
Purge Control Wires:
1 Yellow/Black
1 Red/Yellow
Back
Code 13 - Atmosphric Pressure Sensor
The PA sensor should read close to the MAP sensor of 2.75v, this may very small amounts due to current weather conditions and elevation. Due to it's location, it is probably easier to check the voltage at the ECU. This sensor vary seldom, or never at all should fail. Flooding may have damaged it, at one time or another.
Back
Code 14 - Electronic Air Control Valve
Lets extra air into the intake manifold, to help control the idle under different loads.
Check the O-rings, for mountng condition.
Clean the inside of the Valve after removing, using any kind of solvent that will remove carbon build up. By spraying it inside the two holes ect...
Place the flat end of a screw driver on the EACV while the engine is running. Place the handle against your ear and listen. Should hear something in there jumping back and fourth at a rapid rate.
EACV Sensor Wires:
1 Blue/Black
1 Yellow/Black
Back
Code 15 - Ignition Output Signal
Something is wrong with the referance voltage, the ECU is receiving from the igniter.
The only way to check this, is with a Volt Meter of some kind, or ocs-scope. The latter being the most accurate. Sooo, that means a trip to a shop, that has this kind of equip...
Most peeps just end-up replacing the dist.. However, you can DYI if you have the tools and manual...
Back
Code 16 - Fuel Injector
Code 16 is probably the Main Relay, however it could still mean a bad Injector, Resistor Box tho.
Most failures occur, when the weather starts heating-up for the summer...
If the car refuses to start, but "turns over" on a hot day, try opening the doors/windows, and let the interior cool down. "Then try starting again". May not work all the time, but worth a try anyway. Also, would help in troubleshooting the prob, if it does start. Another place to look is the ECT sensor, refer to the above
Back
Code 17 - Vehicle Speed Sensor
Sorry, still working on it....
Back
Code 19 - Lock Up Control Solenoid (auto trans only)
Back
Code 20 - Electric Load Detector
First make sure you have a good battery....
Open the Main Fuse box lid (Right side shock tower).
Disconnect the 3 point connector, from the ELD unit. (Follow the harraness that runs through the box).
With the ignition switch ON, there should be battery voltage between the BLK/YEL(+) and BLK(-) terminals.
If there is no voltage, check for:
Blown No. 14 (10A) fuse in the dash fuse box.
An open in the BLK/YEL(+) wire between the dash fuse box and the main fuse box.
Pour ground (G201)
If there is voltage then goto the next step.....
Check for voltage between the GRN/RED terminal and body ground with the ignition switch ON. There should
be approximately 5V.
If the voltage(5V) is not specified, check the alternator control system.
If the voltage is as specified then goto next step.....
Connect the 3 - Point Connector to the ELD unit.
Check for volatage between the GRN/RED terminal and body ground, with the ignition switch ON and turn on the
headlight low beam's.
There should be approximately 2V.
If the voltage(2V) is not specified, replace the main fuse box (ELD unit is not available separately)
If the voltage is as specified above, ELD unit is OK.
Back
Old Mar 13, 2006 | 05:08 PM
Default Re: ECU codes, code , explanation (90blackcrx)
Feel free to add pics of the component and the code it relates to.
Old Mar 13, 2006 | 05:20 PM
phoenix_iii's Avatar
From: Close to West Chester, PA, United States of America
<3 sticky/faq this. =D
p3
Old Mar 13, 2006 | 08:26 PM
doublethink's Avatar
^^^^^^^^^^^ mint mint mint!
pwnage.
Old Mar 14, 2006 | 01:45 PM
Old Mar 18, 2006 | 03:27 PM
bump awesome info, please finish!
Old Mar 24, 2006 | 04:51 PM
attica's Avatar
hey my ecu blinks 10 times in a row.i have a sohc zc any ideas what that would be?
Old Mar 24, 2006 | 05:06 PM
Its me DUB's Avatar
Default Re: ECU codes, code , explanation (attica)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by attica &raquo;</TD></TR><TR><TD CLASS="quote">hey my ecu blinks 10 times in a row.i have a sohc zc any ideas what that would be? </TD></TR></TABLE> hmm, did you take the time to read above?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">Code 10 - Intake Air Temperature Sensor
IAT Sensor Wires:
1 Red/Yellow
1 Green/White
Back
Old Mar 25, 2006 | 05:26 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">Feel free to add pics of the component and the code it relates to.</TD></TR></TABLE>
Old Apr 3, 2006 | 04:58 AM
h22_crx's Avatar
that helps
Old Apr 3, 2006 | 05:00 AM
Autoworks's Avatar
Default Re: ECU codes, code , explanation (h22_crx)
interesting
Old Apr 16, 2006 | 07:24 PM
jdmazm's Avatar
Default Re: ECU codes, code , explanation (Autoworks)
definately tell tyson to put this in FAQs, everyone is always looking for ecu info and codes.
Old Apr 18, 2006 | 11:03 AM
thrty8street's Avatar
Default Re: ECU codes, code , explanation (jdmazm)
what if the light on the ecu lights up a steady red when i put the key in the #2 position and doesnt change at all?
I read somewhere that this means that the ecu is bad, is this true?
Old Apr 18, 2006 | 03:26 PM
richboi's Avatar
How do u know when ur car is giving out codes?...cuz damn i have no clue!
Old Apr 18, 2006 | 03:42 PM
Default Re: ECU codes, code , explanation (richboi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by richboi &raquo;</TD></TR><TR><TD CLASS="quote">How do u know when ur car is giving out codes?...cuz damn i have no clue!</TD></TR></TABLE>
There is a check engine light on (CEL) and you check it by looking on you ecu. On the ecu there will be a light in the center which will flash. 1 short flash is denoted as "1" and a long flash is denoted as "10". you count it and look in the shop manual or online and see what each code refers to.
Old Apr 18, 2006 | 03:45 PM
richboi's Avatar
Default Re: ECU codes, code , explanation (thrty8street)
so if theres no check engine lite then..ur fyne?...jus i think my engine is actin up
and..so if it blinks a few tyme?..jus count them to find out ur prob?
Old Apr 18, 2006 | 03:47 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by richboi &raquo;</TD></TR><TR><TD CLASS="quote">so if theres no check engine lite then..ur fyne?...jus i think my engine is actin up
and..so if it blinks a few tyme?..jus count them to find out ur prob?</TD></TR></TABLE>
yeah if theres no check engine light then your fine, here is a link that explains the codes and stuff
https://honda-tech.com/zerothread?id=468260
Old May 7, 2006 | 12:05 PM
PINKS's Avatar
I want a CRX tattoed on my butt
Best info Ive ever read
Old May 7, 2006 | 12:09 PM
SiR Inspired ED7's Avatar
This should be a sticky good job
Old Jan 2, 2009 | 12:50 PM
brandyboo78's Avatar
vehicle speed sensor is a speedometer cable. had that problem and it threw that code, replaced it and code went away and never returned.
Old Aug 14, 2009 | 09:32 AM
attica's Avatar
yeah i have a d15b and i dont understand.i fixed my o2 my tps and my ect.now when i start my car my check engine light is off.but when i drive for a few minnuts it will come back on.yesterday it took my light to come on after about 15 minnuts of driving.so i connetced the wire to the thing and turned my car to on and my engine light will blink 3 times which is my map.....but i cant find the plug to plug in my map.the map sensor is on my throttle body and i can see it.but i dont know where my plug is???im running rich as well.any one know where to look for my map plug?
Old Oct 11, 2009 | 08:17 PM
orb's Avatar
orb
While having an idle issue, I searched, found this post, and it helped me. Just wanted the OP to know. Thank you sir!
Old Oct 12, 2009 | 04:09 AM
jombiee's Avatar
cool stuffs, stick em up !
Old Aug 21, 2011 | 10:37 AM
Monko's Avatar
So my d16a6 was throwing a code 2 and a code 15. I took it to a shop and they said my cat had a hair ball. So I chopped it off and replaced the o2 sensor. That fixed the code problem. Now I have a blown head gasket and my valves are leaking. Is that just from back pressure cuz of the cat problem?
Old Aug 21, 2011 | 11:11 AM
KINGVEM^^ED6's Avatar
no
