simple yes or no... help thanks.
will the integra JDM integra type-R header (2.5 collector) bolt up to a JDM b16, b18 (non type-R)? i've searched and there's something about welding the flange on the exhaust manifold inlet? i'm confused.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teggy182 »</TD></TR><TR><TD CLASS="quote">yes and just buy one with the flange on it</TD></TR></TABLE>
i'm not sure what you mean by that? i mean is the JDM ITR header compatible to the b16 or b18 blocks with no modification straight out of the dealership.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the soL that could »</TD></TR><TR><TD CLASS="quote">
is the JDM ITR header compatible to the b16 or b18 blocks with no modification straight out of the dealership.</TD></TR></TABLE>
^^^Yes.
The 2.5" collector needs to be modified to fit the USDM spec catalytic converter I believe.
^^^Yes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tornadom »</TD></TR><TR><TD CLASS="quote">
^^^Yes.
The 2.5" collector needs to be modified to fit the USDM spec catalytic converter I believe.</TD></TR></TABLE>
You mean no right?
^^^Yes.
You mean no right?
