D16 Vtec Swap
Old Mar 13, 2006 | 02:56 PM
dirthonda's Avatar
Default D16 Vtec Swap
Does anyone have a list of items and a link to a how to page on swapping a vtec d16 into my '91 crx hf 5 speed. Any help on this would be great!! Race season is just around the corner.
Old Mar 13, 2006 | 02:57 PM
dirthonda's Avatar
Default Re: D16 Vtec Swap (dirthonda)
Also if anyone knows where there is a d16a6, d16z6, or d16y8 for sale in the midwest area let me know.
Old Mar 13, 2006 | 02:58 PM
si0385.'s Avatar
swap info!
everything you need to know
motors for sale!
and anymotor you want here
Old Mar 13, 2006 | 03:01 PM
dirthonda's Avatar
I searched for about 2 hours and i couldnt find a list of the items i needed. I also couldnt find an install guide.
Old Mar 13, 2006 | 03:07 PM
si0385.'s Avatar
Default Re: (dirthonda)
the z6 will bolt right in
being you are already mpfi you wont have to wory about converting from dpfi to mpfi
you will need a ob0->ob1 conversion harness
obd1 sohc distributor
p28 ecu
4 wire o2 sensor
rywire
^they have the conversion harness, o2 sensor, and ecu for sale (sorry but i think you can find a used dizzy alot cheaper than that, i found one for $40)
Old Mar 13, 2006 | 03:08 PM
si0385.'s Avatar
also make sure you change that tranny or you wont be satisfied with the swap... get a 90-91 crx/civic si tranny
Old Mar 13, 2006 | 03:17 PM
dirthonda's Avatar
I will eventually change the tranny, but i dont have the cash right now to do it. Will the y8 bolt right in? Will it run alright without the 4 wire o2 sensor?
Old Mar 13, 2006 | 03:20 PM
si0385.'s Avatar
the y8 will bolt right up... with out the 4 wire o2 sensor it will not have vtec but it will still run
there is other ways of controling vtec but converting to obd1 is the best way
Old Mar 13, 2006 | 03:24 PM
dirthonda's Avatar
Awesome!! Thanks so much!! How do i identify the transmission i want? Is there any links to step by step guides on this install?
Old Mar 13, 2006 | 03:33 PM
si0385.'s Avatar
this thread is good
mista bone is the tranny guru on this site he prety much knows all
Old Mar 13, 2006 | 03:37 PM
AutoStrada048's Avatar
Search?
Old Mar 13, 2006 | 03:39 PM
dirthonda's Avatar
Thanks so much! One more question, do you know where the rev limiter is with the p28?
d16vtecx
11
Jul 24, 2006 03:08 PM
Screaming
Jan 29, 2006 06:53 PM
sleepin91teg
Jun 20, 2005 09:40 AM
ironcheftony
Dec 19, 2003 04:57 AM
