Stripped head on AEM Cam Gear Bolt
Old Mar 13, 2006 | 02:52 PM
tl hatch's Avatar
Default Stripped head on AEM Cam Gear Bolt
I have AEM 3 bolt cam gears with the hex head bolts and one is stripped (from previous owner). I can probably dremel a slot for a screwdriver in the head so I'm not worried about that.
Anyone know where to get a replacement? AEM will probably charge a grip.
Hardware store? Home Depot? Anyone ...
Old Mar 13, 2006 | 07:22 PM
tl hatch's Avatar
Default Re: Stripped head on AEM Cam Gear Bolt (jklobo)
Old Mar 13, 2006 | 08:52 PM
Batoutahell's Avatar
Check with your local hardware store. Instead of replacing it with an identical hex key bolt that will just strip out again, just get a regular bolt.
Old Mar 13, 2006 | 09:26 PM
tl hatch's Avatar
Default Re: Stripped head on AEM Cam Gear Bolt (Batoutahell)
Good idea, I'm totally on board with that. I used my dremel tonight to cut a slot in the head to get it out with a screwdriver.
Old Mar 14, 2006 | 08:46 AM
d16dcoe45's Avatar
When I had the old style 3-bolt AEM cam gears, they came with these small head alllen bolts. I simply went to the hardwear store and got some grade 8 allen bolts with much beefier heads but the same diameter and thread pitch. Measure the thread pitch, length, and diameter of the bolts.
Old Mar 14, 2006 | 08:54 AM
RPRacing's Avatar
they arent that expensive from AEM if i recall correctly.
Old Mar 14, 2006 | 08:57 AM
tl hatch's Avatar
Default Re: (RPRacing)
I'll probably do the hardware store thing. Thanks for the ideas guys!
WalkerGSR1
Apr 18, 2007 07:53 PM
solfood
Mar 24, 2006 11:09 AM
tl hatch
Mar 13, 2006 01:33 PM
Mr. Softee
Apr 29, 2002 11:04 AM
