Car died on highway please help
All right guys my 91 Si hatch suddenly died today while on the highway. It cranks but it wont start. Main relay is new, distributor, cap and rotor have been replaced 2 months ago with a rebuilt unit from autozone. Anybody have any ideas? I am guessing that the fuel pump is bad but then again I've never heard of it going bad on hondas. The car is in Jaksonville my girlfriend was driving it when this happened (today in the morning) so I cannot check what the f%$# is going on (I am in Tallahassee).I had her check for spark and the dizzy seems to be fine.
I do not want to have her take it to a shop since it will be expensive. Suggestions are greatly appreciated.
Thanks
Thanks
my crx did the same thing. but it turned out the rebuilt dizzy i bought was a piece and fried and the spark wasnt gettin to the plugs. i checked fuel and everything was ok. try using a dizzy u know works i borrowed my buddies to see and it started right up. mine would also jus crank but never start
From: Close to West Chester, PA, United States of America
Autozone Dizzy's are known to be POS's, I'm sad to report. I've read this time, and time again. They just do not work well. You can either repair your original or go to the pick and pull and find one that way.
p3
p3
there was jus no spark gettin to the plugs a POS dizzy. its jus fried i guess. changed everything and still didnt work so i jus bought a new one for 149
. mine would crank n crank but never fully start. it started once and then died right away.
check the rotor in the dizzy. The little screw comes out..and when it does...the cars sputters and puts til it eventually stops completely. Happened to me on valentines day
and happened to my homeys crx all the time. Btw if that is ur prob put locktite on the screw before u put it back. Good luck. I am 90% sure this is probably the case.
I requested a short story for a title.
possibly timing belt? i had this happen to a friend in his eclipse while he was driving. belt all his valves.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blaqman »</TD></TR><TR><TD CLASS="quote">check the rotor in the dizzy. The little screw comes out.</TD></TR></TABLE>
Thanks for all the feedback guys. It all came down to the timing belt. The shop says the timing is way off and that the belt has too much slack. It is very weird since it was replaced about a year ago in a shop and the car ran fine the entire time. I would like to know if you guys have any experience with this matter.
Thanks
Thanks
indy_parrothead
May 5, 2003 11:15 AM
MysteryWagon
13
Apr 15, 2003 01:14 PM
