need help
From: if you build it they will come, the bottom carolina, duh
i have a ls that was in my integra and i threw like 7 different codes, so i thought it was just the computer, (is now bad), so couple months go by and i started to swap the engine into my crx, and now it is still doing the same thing, it starts it is just really ruff, idles good, just bogs every tiime i give it some gas, it has new dizzy, iac, and the sensor under the throttle body for the cold start, i have different injectors in as well and it is still doing the samething, also check the timing, also good, have a chipped pm6 for tuning.
does anyone have an idea of what could be the problem
thanks for the help
thanks for the help
BLU CIVIC
Sep 17, 2007 08:13 PM
