h22 alternator tensioner bolt
Can someone give me the exact position for the alternator tensioner bolt for my h22? I'm stuck in a parking lot with my sidekick and my belt flipped. I've searched but I can't find a clear pic. I remember it being 1 bolt that made the altrnator swing down, thanks a lot
Thanks man, I remember when it was on the lift it was 1 bolt towards the bottom. But then I read in the diy and it told me to loosen like the bolts for the bracket but I never did that.
theres one that goes from the front of the alternator towards the firewall, that is the tensionor. You have to loosin the bolt that goes from left to right from the bottom of the alternator first.
the tensioner bolt head is a 10mm, and the one that goes from passenger side to driver side is a 12mm. You have to loosen the 12mm 1st before you can adjust the tension.
