cleaning air intake filter
Old Mar 12, 2006 | 11:12 PM
sp0097's Avatar
Default cleaning air intake filter
Hi,
I have a short ram air intake installed on my civic, but I don't know which brand it is. I got the intake from my bro who took it off a civic he recently bought. I don't really know how many miles the filter has been through. I put it on my car last november and probably put around 3-5k miles on it. I wanted to clean the air filter, but how should I clean the filter? Are there products I can buy, or are there household products that I can use to clean the filter.
Old Mar 13, 2006 | 12:30 AM
teknoracing's Avatar
Default Re: cleaning air intake filter (sp0097)
What kind of filter is it?? If it looks like a K&N, use the cleaner and oil that you can get at your local auto parts. If its stainless steel, soap and water will help clean it up.
Old Mar 13, 2006 | 06:30 PM
sprayinBseries's Avatar
you cant clean a filter you just have to buy a new one, they never work the same after you try to clean them
Old Mar 13, 2006 | 06:34 PM
old man neri's Avatar
Default Re: cleaning air intake filter (slammedeg693)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammedeg693 &raquo;</TD></TR><TR><TD CLASS="quote">you cant clean a filter you just have to buy a new one, they never work the same after you try to clean them
Wrong. Some you can't clean some you can. K&N makes some filters you can clean
Old Mar 13, 2006 | 06:38 PM
dreww..'s Avatar
expletive that, blast it with an air gun and throw it back on
Old Mar 14, 2006 | 02:34 AM
Evolution-93-Ex's Avatar
From: Your mommas bed, that might be true too ..., So Cali, USA
Default Re: (dreww..)
swish it around in soap and water, let it dry, put it back on you'll be fine
Old Mar 14, 2006 | 03:17 AM
1fastcivicGX's Avatar
Default Re: (Evolution-93-Ex)
what's an air filter?
Old Mar 14, 2006 | 04:14 AM
AfricanBush's Avatar
Default Re: (1fastcivicGX)
it filters the air.
Old Mar 14, 2006 | 07:31 AM
sp0097's Avatar
Default Re: cleaning air intake filter (teknoracing)
The filter itself looks like a K&N type (cone shape), I don't know what the material is (some kind of fibrous material), but the filter is not stainless steel. I will check out the stuff at the local shops, but can I use soap and water for the filter, I described above?
Old Mar 14, 2006 | 07:17 PM
thats what i did on my aem filter it works fine as new, just dont soak it where the filter material gets all loose cause then it most likely will fall apart
Old Mar 14, 2006 | 07:42 PM
Black4thgenEF's Avatar
Default Re: cleaning air intake filter (Evolution-93-Ex)
If it's a k&n you can buy the cleaning kit for about $10 - comes with soap and oil. If you wash it, it needs the oil on it afterwards to filter properly. Wash from the inside out.
kcari
Honda Civic (2001 - 2005)
Aug 4, 2007 01:40 PM
noltofan69
Jan 1, 2006 03:24 PM
oh-k
Feb 8, 2005 09:24 AM
gsr94
May 31, 2004 01:41 PM
PetroGuyX
Jul 24, 2003 06:21 AM
