Question about radiator, radiator fan and oil cooler
Old Mar 12, 2006 | 06:59 PM
Mugen_DC2R's Avatar
Default Question about radiator, radiator fan and oil cooler
If i want to change the stock radiator to sth like the spoon or ARC, could i use the stock OEM radiator fan?
Also if i change the radiator and put a Greddy oil cooler on the R, would it be too much?
Thx for ur time and input
Old Mar 12, 2006 | 07:33 PM
Mugen_DC2R's Avatar
Default Re: Question about radiator, radiator fan and oil cooler (neo_)
i actually bought the oil cooler already, but i don't have time to put it on yet.
The reason i bought the oil cooler is that i often go to the track. so having a oil cooler can let me stay on the track for a longer time, and goods for the engine.
for radiator, i am getting a good deal on them.
Modified by Mugen_DC2R at 11:44 PM 3/12/2006
Old Mar 12, 2006 | 08:34 PM
JjuuN R's Avatar
how do you figure it'll let you stay on the track longer?? i've done a couple of hard driving HPDE events@Infineon with the stock radiator and still have yet to go past the half way point in my temp guage, it's not needed... at all
Old Mar 12, 2006 | 08:51 PM
Mugen_DC2R's Avatar
Default Re: (JUN.R)
i know the water temp gauge is not going to beyond half way after hard driving, but a larger radiator can keep ur engine cooler, isn't it?
Old Mar 12, 2006 | 08:58 PM
Mike K's Avatar
Default Re: (Mugen_DC2R)
a larger radiator isn't needed.
an oil cooler? i don't see it doing any harm, and if you feel like spending money on it, then that's great. but there are a ton of other things you can do first that would be more beneficial.
Old Mar 12, 2006 | 09:03 PM
Mugen_DC2R's Avatar
Default Re: (Mike K)
what other things, should i do?
Old Mar 12, 2006 | 10:54 PM
Circuit Star-29's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike K &raquo;</TD></TR><TR><TD CLASS="quote">a larger radiator isn't needed.
an oil cooler? i don't see it doing any harm, and if you feel like spending money on it, then that's great. but there are a ton of other things you can do first that would be more beneficial.</TD></TR></TABLE>
Agreed.
After installing a Spoon temp switch and thermostat, I can't reach proper operating temp...this is in addition to a Fluidyne Rad, which was more then enough it would seem for cooling.
However, I also believe that it would be VERY necessary to purchase and install and oil cooler. Cool oil is crucial on a hot day. Also, get BAFFLES installed in your oil pan. Especially if you end up running R compound tires.
One thing I would worry about is brake pads and lines. Also, get your suspension figured out.
Brake fade and understeer will kill the fun of an HPDE.
Old Mar 13, 2006 | 05:39 AM
RagingAngel's Avatar
Default Re: (Circuit Star-29)
I completely disagree with everything.....
I would get a set of aftermarket gauges and then decide what to upgrade next.
Yes it makes perfect sense that the oil and water temps will go up when you hit the track.... but even so, having a bigger rad and an external oil cooler does not guarantee that you will not exceed safe operating temps.
Upgrading "everything" without monitoring is a false sense of security.
Old Mar 14, 2006 | 12:42 AM
Default Re: (RagingAngel)
^^^ AGREED... My next purchase...
g0tgot
Jan 17, 2011 07:06 PM
Jonathan_ED3
Jul 25, 2003 10:01 PM
drive
Mar 1, 2002 07:11 AM
eurodeseo
Jan 19, 2002 11:21 AM
