best thing to do w/ hole in intake and hole in motor head?
Old Mar 12, 2006 | 05:59 PM
EGhatch33's Avatar
Default best thing to do w/ hole in intake and hole in motor head?
ok, so like it says, i'm tryin to figure out what the best thing is to do w/ those two holes and i'm hopin somebody has some advice. i know i could get two breathers and pop those on, or get a catch can for the oil, or should i use the tube to link them together?
Old Mar 12, 2006 | 06:12 PM
crazi_E's Avatar
Default Re: best thing to do w/ hole in intake and hole in motor head? (EGhatch33)
blow in one hole nd play it like a flute
Old Mar 12, 2006 | 06:15 PM
nighttrain33's Avatar
I plugged the hole in the intake and got a breather filter for the head. I heard some bad things about hooking them up together, although I originally had mine that way and never had a problem.
-Shane
Old Mar 12, 2006 | 06:30 PM
x_outlaw_x's Avatar
why would it be bad if it comes from the factory like that?
Old Mar 12, 2006 | 06:35 PM
Wharbone's Avatar
Breathers are stupid. Just link them together as it came originally.
edit: also, this would be an incorrect place to put an oil catch can since it is sucking air into your valve cover. You would put a catch can at your PCV valve.
efsedanb20
Jul 17, 2014 06:22 AM
jeremyrocksursox
Jan 18, 2009 10:03 AM
jvk
Aug 21, 2008 09:59 AM
Corey_sl
18
Apr 6, 2008 06:56 AM
variablevalve
May 1, 2004 02:50 PM
