90 Si w/LSVTEC shakes real bad under load.
The Tie rods look fine but the car shakes like crazy under a load. I was thinking the axles might be wore out and in the case of prior experience a possable diff bearing. Anyone had this problem and fixed it??
Cj
Cj
Iv gotton vibration like that when my intermediate shaft was going out
But it could have been the axles because i changed them all out at once and the vibration was gone
Do your axles chunk around corners?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4thgenhtch »</TD></TR><TR><TD CLASS="quote">Iv gotton vibration like that when my intermediate shaft was going out
Do your axles chunk around corners?</TD></TR></TABLE>
Really? the intermediate shaft was going out?
Do your axles chunk around corners?</TD></TR></TABLE>Really? the intermediate shaft was going out?
Well I am coming to the conclusion that the trans has a bad diff bearing and the intermediate has a bad carrier bearing.
I also noticed that with the suspension hanging, as I rotate the drivers side tire the suspension moves up and down because of the carrier bearing.
Can someone link me to the no BS axle info on a 2G CRX with a B-swap?
Thanks for the replies guys.
Cj
Cj
i had the same prob also. i was using 90-93 integ(hasport said they would work) axles on my b16 w/s1 tranny. My one friend told me about the 89 teg axles for his setup so I put in a 89 teg axle on the drivers side and shaking went away when i punched the gas.
Hopefully thats you prob too
roadracewade
Dec 6, 2004 01:30 PM
