B18A1 in Gen3 GSR swap ?
Old Mar 12, 2006 | 01:36 PM
JBrynt1's Avatar
Default B18A1 in Gen3 GSR swap ?
what all is required to swap a B18A1 from my 90' GS into my 95 GSR?
Old Mar 12, 2006 | 01:54 PM
SOHC SOLDIER's Avatar
Default Re: B18A1 in Gen3 GSR swap ? (JBrynt1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JBrynt1 &raquo;</TD></TR><TR><TD CLASS="quote">what all is required to swap a B18A1 from my 90' GS into my 95 GSR?</TD></TR></TABLE>
why do you want to do that? did your gsr motor blow?
Old Mar 12, 2006 | 05:08 PM
JBrynt1's Avatar
Default Re: B18A1 in Gen3 GSR swap ? (SOHC SOLDIER)
I bought the GSR with no motor or tranny . I wrecked my 90 GS a couple months ago. Its a golden eagle block (slightly shortned), performance cams/timing Gears, 3 angle valve job, arians 11:1 domed pistons, makin about 240 at the wheels, plus later i can get a vtec head.
Old Mar 12, 2006 | 06:04 PM
Nevets's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JBrynt1 &raquo;</TD></TR><TR><TD CLASS="quote">I bought the GSR with no motor or tranny . I wrecked my 90 GS a couple months ago. Its a golden eagle block (slightly shortned), performance cams/timing Gears, 3 angle valve job, arians 11:1 domed pistons, makin about 240 at the wheels, plus later i can get a vtec head.</TD></TR></TABLE>
240 at the wheels huh? You wouldnt happen to have a dyno graph would you?
Old Mar 13, 2006 | 10:33 PM
what 240hp to the wheels?
Old Mar 14, 2006 | 12:15 AM
PyeeK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC SOLDIER &raquo;</TD></TR><TR><TD CLASS="quote">what 240hp to the wheels?</TD></TR></TABLE> seriously????
Old Mar 14, 2006 | 12:24 AM
DA9ReMiX's Avatar
Default Re: B18A1 in Gen3 GSR swap ? (rotate-da)
240 to the wheels? ..... since u had a 90.. it's a OBD0 nd you GSR is OBD1... you're gon need the harness
805_Slow_Master_93EG
Nov 17, 2007 09:13 PM
michael123
Feb 14, 2007 07:31 PM
r1de4life
Oct 30, 2005 11:09 AM
joejoewan
Feb 8, 2005 12:03 AM
Wattup Though 00
May 7, 2004 10:49 AM
