89 dx hatchback rear disc conversion ???????
Old Mar 12, 2006 | 12:13 PM
4gencivicef9's Avatar
Default 89 dx hatchback rear disc conversion ???????
I bought a 91 teg rear suspension with the calipers and the rotors and brake line and e brake cables what else do I need for this to work......please helpp thanks...
1989 civic hatchback (b16a y1 trans....)
Old Mar 12, 2006 | 12:33 PM
uglyrex's Avatar
Default Re: 89 dx hatchback rear disc conversion ??????? (4gencivicef9)
do a search on the forum very old question lots good info on it out there! just do a search
Old Mar 12, 2006 | 01:09 PM
VtecSyndrome's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4gencivicef9 &raquo;</TD></TR><TR><TD CLASS="quote">I bought a 91 teg rear suspension with the calipers and the rotors and brake line and e brake cables what else do I need for this to work......please helpp thanks...
1989 civic hatchback (b16a y1 trans....) </TD></TR></TABLE>
As long as you have the rear trailing arm with all the stuff attached then it will bolt right up and that is all you need.
Old Mar 12, 2006 | 01:20 PM
civickiller's Avatar
Default Re: 89 dx hatchback rear disc conversion ??????? (VtecSyndrome)
you might want to change the trailing arm bushings
Old Mar 12, 2006 | 01:29 PM
thanks for the response.....
Old Mar 12, 2006 | 01:37 PM
Riceburner247's Avatar
The integra arm sticks out 1/4" more than the stock trailing arm. If you're lowered, you might have issues with rubbing. Or you can swap out the entire brake setup and mount it onto your stock civic trailing arm, it bolts right up.
When installing the trailing arm, there is an adjustment bracket on the front of the TA. Don't touch it. Although you <U>should</U> always get your **** aligned after any suspension work, if your short on cash this will save your tires from going to hell in a matter of weeks. Just unbolt the TA from that adjustment bracket and go from there, don't unbolt the bracket.
When I swapped out my stock TA for the integra one, I went ahead and had the wheel bearings replaced in them as well. It easier to do while it off the car anyways.
Make sure the pads have enough left on them before you put everything back together. Don't forget to bleed the brakes after all is said and done.
That's all I can think of.
Old Mar 13, 2006 | 05:16 PM
Default Re: 89 dx hatchback rear disc conversion ??????? (Riceburner247)
to take the drum apart and put the disc their,,,, do you have the write up or what I would have to do, to do that........
Old Mar 15, 2006 | 03:59 PM
richboi's Avatar
A whole lot easier if u jus got the rear disc brakes and arms.from an actual civic.....they have a **** load on ebay
Old Mar 15, 2006 | 04:08 PM
Default Re: 89 dx hatchback rear disc conversion ??????? (richboi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by richboi &raquo;</TD></TR><TR><TD CLASS="quote">A whole lot easier if u jus got the rear disc brakes and arms.from an actual civic.....they have a **** load on ebay</TD></TR></TABLE>
Agreed, it is quicker and easier to just swap the entire trailing arm with the disc already intact. I have not heard about the integra setup sticking out farther than the civic but I have seen it done enough to believe it won't be a problem. Just get the E-brake cables for the disc brakes and everything else will botl right up.
eckoboy008
11
Oct 3, 2007 03:44 AM
socalrex88
Jul 17, 2007 03:08 AM
sijeff
Jun 6, 2005 01:32 PM
NsX_CrX
May 28, 2004 08:21 AM
91b16a
Mar 27, 2002 05:14 PM
