LS VTEC problems
Old Mar 12, 2006 | 11:19 AM
gen2b20vtec's Avatar
Default LS VTEC problems
Im going to a ls vtec in my 91 Si, just wondering what ecu you used. I was told that the PR3 is to lean for the ls with type r pistons
Old Mar 12, 2006 | 12:57 PM
jacoop86's Avatar
Default Re: LS VTEC problems (gen2b20vtec)
cspeedracing used a obd1 gsr p61 on thier lsvtec. i would think that the pr3 would be to lean anyway with or without the itr piston due to the larger displacement. your best bet would probably be any obd1 gsr or itr.
http://www.c-speedracing.com/h...c.php
Old Mar 12, 2006 | 01:12 PM
Default Re: LS VTEC problems (jacoop86)
I was thinking of going to obd1 anyway i guess i can use my skunk2 P28. Just tryin to save money and have access to a PR3. But i dont want to run lean. OBD1 here we go i guess
Old Mar 12, 2006 | 01:20 PM
civickiller's Avatar
why not just buy a fpr and turn up the pressure to compensate for the extra displacement and it running lean?
Old Mar 12, 2006 | 02:08 PM
whiteef8's Avatar
Default Re: LS VTEC problems (civickiller)
misconception, pressure is pressure, not volume, that may help a little bit, but your best bet is to go obd1 say a p28 or p72 your chipped sk2 p28 prolly wouldnt be a bad idea...
Old Mar 12, 2006 | 03:22 PM
Default Re: LS VTEC problems (whiteef8)
Yea im thinking that the chipped P28 will work good. It was crazy when i put this ecu in my 92 teg. I had a P61 and vtec was barly noticable sound wise, I plugged in my chipped ecu and vtec got louder and it actually kick during X-over. Im thinkin converting to obd1 and using this ecu cause i think my ls vtec would love it
Team ICU
Jun 13, 2007 11:11 PM
cmasonrun
Jun 1, 2007 04:56 PM
Youlose1305
Jul 10, 2006 09:16 AM
99EletronblueSI
Oct 18, 2004 07:55 AM
ltho1998
Jul 24, 2003 02:15 PM
