Speed limiter
Old Mar 12, 2006 | 10:38 AM
uncontrolled515's Avatar
Default Speed limiter
how can i eliminate the speed limiter on my 98 civic with a B20 Vtec, its been converted to OBD1 and has a JDM GSR ECU....
Old Mar 12, 2006 | 10:58 AM
tallyturbo's Avatar
Default Re: Speed limiter (uncontrolled515)
if you get your ecu chipped and you use a program like uberdata you can disable the speed limiter.
Modified by tallyturbo at 2:15 PM 3/12/2006
Old Mar 12, 2006 | 11:00 AM
spatula's Avatar
Default Re: Speed limiter (tallyturbo)
you could pick up a field's vtec controller pretty cheap, that will remove the limiter.
Old Mar 12, 2006 | 11:04 AM
SVOboy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tallyturbo &raquo;</TD></TR><TR><TD CLASS="quote">if you get your ecu chipped and you use a program like uberdat you can disable the speed limiter.</TD></TR></TABLE>
Or crome,
Old Mar 12, 2006 | 11:16 AM
tallyturbo's Avatar
Default Re: (SVOboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tallyturbo &raquo;</TD></TR><TR><TD CLASS="quote">if you get your ecu chipped <U>and you use a program like </U>uberdata you can disable the speed limiter.
you know uberdata, crome, hondata and all those good programs.
Old Mar 12, 2006 | 11:25 AM
Syndacate's Avatar
there's no other way around it? No wire to cut?
Old Mar 12, 2006 | 11:29 AM
spatula's Avatar
Default Re: (Syndacate)
there's no free way.
chip the ecu, get rid of the jdm ecu or get a field's vtec controller
Old Mar 12, 2006 | 12:13 PM
SVOboy's Avatar
Default Re: (tallyturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tallyturbo &raquo;</TD></TR><TR><TD CLASS="quote">you know uberdata, crome, hondata and all those good programs.</TD></TR></TABLE>
I was just concuring that you're right and giving the obligatory shout out to crome.
Old Mar 12, 2006 | 12:16 PM
tallyturbo's Avatar
^^^ i agree. my bad for not adding all of them in there.
Old Mar 15, 2006 | 02:56 AM
Syndacate's Avatar
arg, there's g2 be another way around it, I don't want to chip it because I don't want it to run rich and act all gay, I've had too much exp w/ things running rich/lean and ******* with the car, I hate it, and I usually can never fix it, and since there's no dynos around here, I mean, I WOULD do it myself, but then I risk f8king up a 120 buck ECU, and nobody chips it reasonably, want like 70 bucks for 15 minutes of labor + 10 bucks in parts
not to mention I don't even think it's worth it w/o anything on it (only I/E), i mean ****, my next step would be to pull my old laptop out and make a RT tuner...but on a stock? c'mon....
Old Mar 15, 2006 | 07:37 AM
SVOboy's Avatar
Well, it's really not 15 minutes of labor, but you could always just have it chipped with stock maps...
xero-cool
Mar 24, 2007 10:33 AM
fdjizm
Nov 29, 2006 02:32 PM
95accordh22a
Nov 22, 2004 08:06 AM
junek00
Sep 5, 2004 09:58 AM
lke2drvgsr
Jan 9, 2004 07:20 PM
