Just out driving and car started missing bad & CEL blinking
Old Mar 12, 2006 | 09:26 AM
purple98ek's Avatar
Default Just out driving and car started missing bad & CEL blinking
Hello, Just like the title says I just took my car out about 15 min ago and after about 5 min. of normal driving my car started missing bad when i would give it gas. I also noticed that my CEL was blinking. Now, I did have the CEL illuminated for about the last 6 months with no problems. The code i was throwing before was "Fuel Curve Lean"......and nobody could give me a straight answer on what needed to be replaced. I am thinking maybe the primary o2 sensor. My car has new plugs, so maybe i need a new cap, rotor & wires?.....I dont know.....If anyone has any insight it would be much appreciated
Old Mar 12, 2006 | 10:24 AM
purple98ek's Avatar
Default Re: Just out driving and car started missing bad & CEL blinking (purple98ek)
Ok, I just pulled the codes from my ecu.....1) P0171- System too lean 2) P1301- Cylinder 1 misfire 3) P1302- Cylinder 2 misfire 4) P1303- Cylinder 3 misfire 5) Cylinder 4 misfire.........I am now thinking maybe it is a clogged fuel filter? and/or a bad distributor cap/rotor/wires?.......What do you guys think?
Old Mar 12, 2006 | 02:13 PM
purple98ek's Avatar
any ideas?
Old Mar 12, 2006 | 07:54 PM
crv-techu's Avatar
check your spark plugs
Old Mar 13, 2006 | 09:41 PM
purple98ek's Avatar
Default Re: Just out driving and car started missing bad & CEL blinking (crv-techu)
sparkplugs are new and properly gapped.......I replaced the fuel filter today but after driving a while I still get the "fuel curve too lean " code........Anyone have any ideas?
Old Mar 16, 2006 | 05:44 PM
crv-techu's Avatar
bad oxegen sensor? fuel pump?
Old Mar 19, 2006 | 07:04 PM
purple98ek's Avatar
yes, finally figured the problem out........primary o2 sensor.......everything is good now.......thanks crv-techu
fryman
Jan 13, 2011 03:44 PM
Inextricabledrvr
Sep 9, 2009 09:01 PM
hckyNhonda29
Nov 23, 2006 12:24 AM
RHDintegXsi
Aug 21, 2006 03:54 PM
LFA Squad :: iTO
Jun 6, 2006 02:43 PM
