Honda S2000 Honda S2000
Check engine light after Aem V2 Install?
Old Mar 12, 2006 | 09:02 AM
DrewkCarrigan's Avatar
Default Check engine light after Aem V2 Install?
I installed the aem v2 cold air intake and the car is running a check engine light.
I checked all the lines that go to the intake and it looks fine to me and besides that it seems to run even better than before, what could it be it??????? PLease help Thanks.
Old Mar 12, 2006 | 09:37 AM
Francesco's Avatar
Default Re: Check engine light after Aem V2 Install? (DrewkCarrigan)
reset your ECU and drive around a little to see if it comes back on in about 300 miles.
Old Mar 12, 2006 | 01:44 PM
Mr. Projekt's Avatar
* B A N N E D *
Make sure you have EVAP solenoid connected correctly.
Old Mar 12, 2006 | 03:10 PM
JimmieD's Avatar
Default Re: Check engine light after Aem V2 Install? (ProjektSlideways)
i would say you definitely got some vacuum lines crossed. recheck, fix what is wrong and then reset ecu.
Old Mar 12, 2006 | 04:46 PM
Chubz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DrewkCarrigan &raquo;</TD></TR><TR><TD CLASS="quote"> I installed the aem v2 cold air intake and the car is running a check engine light.
I checked all the lines that go to the intake and it looks fine to me and besides that it seems to run even better than before, what could it be it??????? PLease help Thanks. </TD></TR></TABLE>
did you correctly reroute and hook up your vaccum lines
jmarine45lx08
Honda Civic (2006 - 2015)
Dec 27, 2008 12:25 AM
HondaDanny06
12
May 15, 2008 07:30 PM
bcaccord01
Mar 13, 2008 07:15 AM
wrice4
Honda S2000
35
May 12, 2007 09:39 AM
ooooitswilson
Jul 28, 2003 11:02 PM
