Is the S4C tranny really a B16B(CTR) tranny?
Old Mar 12, 2006 | 07:33 AM
vtec25's Avatar
Default Is the S4C tranny really a B16B(CTR) tranny?
i really would like to find this out cuz i keep finding different answers.
Old Mar 12, 2006 | 07:39 AM
Bense's Avatar
we need a tranny forum
Old Mar 12, 2006 | 08:22 AM
MotorMouth's Avatar
Default Re: Is the S4C tranny really a B16B(CTR) tranny? (Hybrid93Eg)
Well since the b16b is a destroked ITR block I would assume that the tranny is the same LSD equipped one as the ITR.
Old Mar 12, 2006 | 08:27 AM
komat's Avatar
Default Re: Is the S4C tranny really a B16B(CTR) tranny? (MotorMouth)
they are the same as the 00-01 civic si tranny
same gearing but with lsd
http://www.ff-squad.com/tech/temp/Bgears.htm
Old Mar 12, 2006 | 09:36 AM
Targa250R's Avatar
be professional
Default Re: Is the S4C tranny really a B16B(CTR) tranny? (vtec25)
Both the EK9 tranny and the EM1 tranny have the S4C code.
Old Mar 12, 2006 | 10:04 AM
vtec25's Avatar
Default Re: Is the S4C tranny really a B16B(CTR) tranny? (Targa250R)
OK so i guess i have the del sol than cuz i have no vins on it.
Old Mar 12, 2006 | 10:23 AM
2000EM1's Avatar
As far as I know it's called the Y80 transmission. Only difference between the two are the fact that the Y80 should have a stock LSD on it.
The gear ratios are the same, as is the final ratio between the Y80 and S4C.
Old Mar 12, 2006 | 11:09 AM
RTI's Avatar
RTI
The S4C is not a CTR transmission. The CTR transmission is the same as 97 and older JDM ITR's and all USDM ITR's.
Old Mar 12, 2006 | 12:16 PM
2000EM1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg &raquo;</TD></TR><TR><TD CLASS="quote">
I had a CTR tranny on my old setup. It was clearly labeled as an "S4C".. </TD></TR></TABLE>
Then you didn't have a CTR tranny, you had either a USDM B16A2 transmission, B16A3 transmission, a JDM SiR2, or a JDM SiR2 transmission with an LSD.
But as far as I'm concerned, who cares? They all have the same ratios.
Old Mar 12, 2006 | 01:00 PM
vtec25's Avatar
well all i know mine has very short gear ratio cuz i be cruising in 4th gear at around 3800rpm's or so at 40mph or so.
could my tach be off?
Modified by vtec25 at 2:39 AM 3/17/2006
Old Mar 12, 2006 | 01:14 PM
bsixteen's Avatar
4th gear, 40mph at 3800rpms doesn't sound right. if i remember i'll test it out tonight when i leave work but i think you'd be under 3800 at 40 in 4th
Old Mar 13, 2006 | 05:43 AM
MotorMouth's Avatar
Default Re: (bsixteen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MotorMouth &raquo;</TD></TR><TR><TD CLASS="quote">Well since the b16b is a destroked ITR block I would assume that the tranny is the same LSD equipped one as the ITR.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg &raquo;</TD></TR><TR><TD CLASS="quote">What does this have to do with anything? He asked if the S4C was a CTR tranny. Not if the B16B was a destroked ITR motor (common knowledge)... Or if the LSD was any different then that of the ITR tranny. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTI &raquo;</TD></TR><TR><TD CLASS="quote">The S4C is not a CTR transmission. The CTR transmission is the same as 97 and older JDM ITR's and all USDM ITR's. </TD></TR></TABLE>
Well Mr. hybrid93eg, the b16b is the ctr motor and since that motor is a destroked Itr motor, and the 99-00 si tranny and usdm itr's share common gear ratios. Honda didn't make another tranny for the ctr they used an itr tranny. Which is what I was saying in the first post.
Waassa matta may englis not gud enuff fo joo to ndastand?
Old Mar 13, 2006 | 06:07 AM
super_nguyen's Avatar
Default Re: (MotorMouth)
the 98+ spec jdm ITR's have the same first 3 gears as 96-97 jdm itr/99-00 usdm si/97-01 ctr/94-95 del sol, but has different 4 and 5 gears and a shorter final drive ratio.
Old Mar 13, 2006 | 10:12 AM
Hybrid96EK's Avatar
Waassa matta may englis not gud enuff fo joo to ndastand?</TD></TR></TABLE>
I know what a B16B is you fool. I also know that its simply a destroked ITR motor, only there is a little more to it then just that. I just fail to see why you felt the need to start blabbing about "the CTR motor is this... " and crap like that.
Old Mar 14, 2006 | 08:26 PM
bsixteen's Avatar
tested it out yesterday. 4th gear, 3800rpm 52mph
VtecNewbie
Jun 18, 2009 10:10 PM
VietSpeed
May 4, 2009 10:23 AM
ebelp
Jul 12, 2004 10:57 AM
Vanilla4215
Jun 10, 2002 10:15 PM
B18C-RnVA
Sep 21, 2001 08:08 AM
