TB adjustment question ( not the idle screw )
Old Mar 12, 2006 | 07:25 AM
crapanese's Avatar
Default TB adjustment question ( not the idle screw )
ok so i have a GSR tb and the idle screw is turned all the way in, and my car still idles at around 1400. it seems as though my tb isnt closing all the way bc when i pull is closed when im messin with it its fine
my question is how do you adjust the tb so the shutter will close all the way. someone told me not to mess with the spring and screw bc its set from factory and its kinda a pain in the @ss to mess with.
anyone got any DIY's or directions on how to adjust the spring so it will close all the way ?
BTW. TB is not dirty, so its not not closing bc of that.
any help would be greatly appreciated
Old Mar 12, 2006 | 08:08 AM
Racermech's Avatar
Default Re: TB adjustment question (crappyDC4)
is the cable too tight? Try to bakc it off jsut a little and see if the idle drops.
Old Mar 12, 2006 | 08:19 AM
crapanese's Avatar
Default Re: TB adjustment question (Racermech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Racermech &raquo;</TD></TR><TR><TD CLASS="quote">is the cable too tight? Try to bakc it off jsut a little and see if the idle drops. </TD></TR></TABLE>
cable tension is fine,
what will happen if i loosen the screw that holds the spring and everythin on ? should i just not mess with it ?
Old Mar 13, 2006 | 08:34 AM
crapanese's Avatar
up for some responses
cydeephek
Nov 30, 2006 04:59 AM
90_civic_Si
Oct 4, 2006 08:36 PM
teletekman
Jul 10, 2006 07:15 AM
631 Teggy
14
Nov 23, 2005 09:11 AM
korndog
Sep 14, 2004 05:59 AM
