So how do I go about this.......
I want to take my D16Y7 and put just the Y8 intake mani on it. Does everything swap over including the throttle body or do I have to have other parts to seal the deal?
Do some boredom searching instead of bumping. If the Honda-Tech search engine isn't cutting it, use Google.
It's called a mini-me. Yes, the Y8 manifold swaps over to the Y7 head. Yes, a Y7 throttle body fits on a Y8 manifold.
Thanks guy....My internet is hella slow here in IRAQ...so I ask the question and pray that someone has the answer. If I were to search this stuff it would take hours and hours.....which I do not have. I'm not a n00b or a postwhore....Normally I never post because I search constantly but now its a little hard when its slower than 56k and I only get a half hour at a time...when it works.
THANK you.....that makes it mad clear? Why the auto intake mani though? What is the diff if you don't mind my askin (cowboy accent)
An auto y8 uses the 3 wire IAC like you use on your y7. If you run a manual y8 youll have to put your throttle body on it and cap off the IAC holes (or have a non used IAC just hanging from it) Ive done this on a few cars and never had a problem.
SOHC_Brian
Jan 15, 2004 08:57 AM
spun Vtec
Jun 6, 2003 03:59 AM
