Power window motor!?
Old Mar 11, 2006 | 08:59 PM
rleonekc's Avatar
Default Power window motor!?
Yeah, my power window motor went out, and a car electric shop told me 300 bucks to fix, is that overpriced?!?
Old Mar 11, 2006 | 09:52 PM
specbb6's Avatar
Default Re: Power window motor!? (rleonekc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rleonekc &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, my power window motor went out, and a car electric shop told me 300 bucks to fix, is that overpriced?!?</TD></TR></TABLE>
u can always check ebay.
I'd just buy the motor and change it myself. I shouldnt require of much knowledge.
Old Mar 12, 2006 | 03:33 AM
P_Adams's Avatar
Depending on what it is that crapped out; yes (and No)
If it's the Drive Motor; Honda reports a $197.00 suggested list price. Depending on the shop's prevailing Labor Rate (and additional parts needed) it could be in the ball park (although I don't see it worth $100 in labor)
If it's the Window Regulator; Honda reports a $70.00 suggested list price. If that's the case, they are out of the ball park.
You didn't specify exactly what they reported it needed...
P
Old Mar 12, 2006 | 07:11 AM
Honda-Master's Avatar
Assuming it is the motor or the regulator that is no good,
if it is from the rear window, motor comes with regulator as an assembly,,I cannot recall if in the front you can get either one .separate,,,,From honda it is quite expensive,, get a non factory motor/regulator ..Autozone sells them ,,if you cannot do the job, take it to a shop and just ask them to install it for you,, Labor should be 1 to 1.5 flat rate hr ,, so depends on their hourly rate , that will be the price to replace it ..
Old Mar 12, 2006 | 10:02 AM
rleonekc's Avatar
Default Re: Power window motor!? (Honda-Master)
yeah its the motor that went out
Old Mar 12, 2006 | 12:34 PM
P_Adams's Avatar
If you're good turning wrenches and can find your way around the inside of your car's door, it's not a stretch that you could install it yourself. Either that or find an Independent Honda repair shop in your local area and have them install it.
As far as the motor is concerned, you can save quite a bit either by:
Buying a known good used motor from a local Auto Recycler
or---
Buy on on-line from either
http://www.hondaautomotivepart...y.jsp
or---
http://www.hondapartsdeals.com/
For about $147.00 USD
or---
http://store.directauto.com/re....html
For between $50.00 to $75.00 for the assembly* (depending on application)
* Motor AND Regulator
P
Modified by P_Adams at 9:47 PM 3/12/2006
Old Mar 12, 2006 | 12:54 PM
BLKFLSH's Avatar
I don't think you can get the motor seperate from the regulator (from a Honda dealer). And from what Magestic Honda lists a regulator for, $300 isn't a bad price (with labor). Link below.
http://www.hondaautomotivepart...GLASS
Old Mar 12, 2006 | 12:56 PM
BLKFLSH's Avatar
Default Re: Power window motor!? (BLKFLSH)
I would go the P adams route. On a car that old.
Old Mar 12, 2006 | 01:15 PM
P_Adams's Avatar
On the '90 Accord
The motor is available seperately for the Front Door Glass:
4Dr EX Sedan:
2Dr EX Coupe:
But, yes; it is not available (seperately) for the rear door glass.
We are talking about the L/S Front door? Correct?
P
Dub C
Oct 8, 2010 05:49 PM
s13hero
Jan 16, 2010 12:21 PM
JDMegCoupe
Jul 23, 2006 11:49 AM
mtpktz.
Jun 12, 2006 06:05 PM
Gennady
Jun 18, 2002 05:23 PM
