Wire VTEC CAR WONT START NOW............. KNOCK CENSOR???? HELP ASAP PLEASE
Old Mar 11, 2006 | 07:28 PM
Kangolbrand's Avatar
Default Wire VTEC CAR WONT START NOW............. KNOCK CENSOR???? HELP ASAP PLEASE
I just wired everything up for vtec... now car wont start... turn the key to on to start, doesnt even try to turn over.... hear fuel pump turn on but still no start or try to start..
If the knock censor is dead would it not start or try to start????
Old Mar 11, 2006 | 07:58 PM
wheelmanbg's Avatar
Default Re: Wire VTEC CAR WONT START NOW............. KNOCK CENSOR???? HELP ASAP PLEASE (Kang
my roommate had a knock sensor code on his ecu but his car still started and ran
Old Mar 11, 2006 | 08:42 PM
pennies_hatchie's Avatar
whats the cel?
make sure that you didnt switch the vtec pressure plug with the temp plug, if so it wont start, dont ask me how i know
Old Mar 12, 2006 | 05:53 AM
crxnj's Avatar
Sounds like a ground issue..I dont know about 92+ cars..But on my crx if you take off the ground from the vtec harness on the thermostat housing it wont start,,Wont even crank at all.. Make sure its grounded good..
Old Mar 12, 2006 | 07:04 AM
nikolass's Avatar
no the knock sensor wont keep it from starting what is your set up?
Old Mar 12, 2006 | 08:09 AM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kangolbrand &raquo;</TD></TR><TR><TD CLASS="quote">I just wired everything up for vtec... now car wont start... turn the key to on to start, doesnt even try to turn over.... hear fuel pump turn on but still no start or try to start..
Knock has nothing to do with it...
A). you knocked the starter solenoid wire off
B). No power to starter
C). Ground issue
Old Mar 12, 2006 | 10:43 AM
found the problem, the starter solenoid wire got knockoff when I was hideing wires. Thanks for the help
kou-integra98
Oct 29, 2013 04:30 PM
cviccoupe
Sep 13, 2006 12:26 PM
streetracerof06
Dec 15, 2005 07:06 AM
duggy
10
Aug 27, 2005 07:01 PM
