h22 revs by itself at idle???
Old Mar 11, 2006 | 07:19 PM
darockstar's Avatar
Default h22 revs by itself at idle???
the h22 revs at idle....the tps on it is adjustable i think....what should i do....some1 also told me about the idle control valve......is there a way 2 maybe clean it so it can function properly??? what should i do
Old Mar 11, 2006 | 07:20 PM
Rudaluda's Avatar
the FITV in the back of the TB adjust that!
Old Mar 11, 2006 | 07:27 PM
darockstar's Avatar
Default Re: (Rudaluda)
what is the fitv on the back of the tps and how do i adjust it....please help
Old Mar 11, 2006 | 09:51 PM
m.c.'s Avatar
Default Re: (darockstar)
it probaly is the idle control valve,
you can take it out and clean it off or replace it, i have never done it but that is what people say
Old Mar 12, 2006 | 10:26 AM
prelude_h22vtec's Avatar
happens all the time, there's a valve under the throttle body. take off the throttle body, take apart the valve assembly, clean it and screw the valve back in tighter when you re assemble it.
Old Mar 12, 2006 | 10:44 AM
ludesrv's Avatar
You simply unbolt the ICV and spray brake cleaner until it's clean, or go to honda and pay 300$ for a new one.
wildoutwhitegsr
Sep 13, 2017 05:57 PM
slo_ej8
May 21, 2008 08:44 PM
EKSedAndy
11
Oct 11, 2007 01:18 PM
matix
Mar 15, 2004 09:28 AM
aj_sir
Jan 14, 2002 10:57 PM
