h22a
Old Mar 11, 2006 | 06:53 PM
nelsond's Avatar
Default h22a
Just installed the h22a but now i get no spark or fuel whats wrong with that also
my check engine light never comes on anymore like when i turn the key and it not
not throwing a code please help
Old Mar 11, 2006 | 09:04 PM
Durkhanus's Avatar
Default Re: h22a (nelsond)
Could you provide us with a little more information, such as the year of your chassis and donor engine, as well as some details like:
You say you get no spark. Does the engine turn over at all when you turn the ignition? Does it make any noise at all when the power is on? Does your dash light up in the normal fashion when you turn the key? Seatbelt alarm sound at all? Do any of your lights work at all, both interior and exterior? If they do, do they dim at all when you try to start it?
Give as much information regarding your installation as you can, such as parts you had to replace, wiring you had to do, things that seemed odd, as well as what the car is, or is not, doing when you try and start it.
Old Mar 11, 2006 | 09:48 PM
specbb6's Avatar
Default Re: h22a (Durkhanus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Durkhanus &raquo;</TD></TR><TR><TD CLASS="quote">Could you provide us with a little more information, such as the year of your chassis and donor engine, as well as some details like:
Give as much information regarding your installation as you can, such as parts you had to replace, wiring you had to do, things that seemed odd, as well as what the car is, or is not, doing when you try and start it.</TD></TR></TABLE>
^^^ we definitely need more info.
congrats on ur new swap.
Old Mar 11, 2006 | 09:52 PM
-Bionic-'s Avatar
Former Sponsor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nelsond &raquo;</TD></TR><TR><TD CLASS="quote">Just installed the h22a but now i get no spark or fuel whats wrong with that also
not throwing a code please help </TD></TR></TABLE>
Ground is a common problem. Make sure it's well grounded.
Old Mar 12, 2006 | 09:41 AM
nelsond's Avatar
Default Re: h22a (-Bionic-)
93 accord h22a the engine turns over great just no fuel or spark and its grounded
very well i used the cb7 tuner swap matrix
Old Mar 12, 2006 | 10:20 AM
NAiL05's Avatar
You sure everything is plugged in?
Old Mar 12, 2006 | 12:58 PM
nelsond's Avatar
Default Re: (NAiL05)
yeah iam gonna go test the wires and see if they are hot and if not it might be a relay
Old Mar 12, 2006 | 05:39 PM
momstaxi's Avatar
Default Re: (nelsond)
sounds like a transmission housing to chassis ground not connected...
Old Mar 13, 2006 | 03:00 AM
nelsond's Avatar
Default Re: (momstaxi)
there is some big blackwire that is grounded to the tranny tho is that what you are talking about
Old Mar 13, 2006 | 05:57 PM
-Bionic-'s Avatar
Former Sponsor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nelsond &raquo;</TD></TR><TR><TD CLASS="quote">there is some big blackwire that is grounded to the tranny tho is that what you are talking about</TD></TR></TABLE>
Yeah and there are three or four more grounds..do you have them all covered?
Old Mar 14, 2006 | 01:50 AM
OuttaGas's Avatar
THERE IS A GROUNG WIRE ON THE THERMO HOUSING MAKE SURE YOU GOT THAT ONE TIGHT. (I MADE THAT MISTAKE.)
Old Mar 14, 2006 | 04:39 AM
nelsond's Avatar
Default Re: (95CIVICLSR)
we got it now it was the blackwire for the thermo housing
preludecrazy
Nov 22, 2015 11:53 AM
paulstewart
Jan 5, 2014 10:43 PM
1994lude
Nov 23, 2010 01:04 AM
davidtran
Apr 15, 2009 08:34 PM
HybridEkH22
Mar 10, 2006 07:12 AM
