Removing A/C Clutch Relay, and Condenser Fan Relay from engine bay... ???
Im slowly working on a wire tuck on my 88 CRX Hf. I already removed my A/C lines, compressor, bracket, condenser, etc... all thats left is the wires that run over from the two relays behind the pass headlight. What can i do about removeing these wires all together since i wont be running a/c anyways?? Do i need to trace them back to wherever they are connected and 'unpin' them?? or can i just cut them back and tape off the ends?? Any help would be greatly appreciated.
Thanks in advance
-justin
Thanks in advance
-justin
these are the relays im talkin about...
i just want to make sure i can do this before i try it. anyone that has done a wire tuck want to chime in???
if i were you i would just tuck them away in where you cant see them just incase you ever want a/c again or if you ever decide to sell you can get more for the car cuz of the a/c
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by si0385. »</TD></TR><TR><TD CLASS="quote">if i were you i would just tuck them away in where you cant see them just incase you ever want a/c again or if you ever decide to sell you can get more for the car cuz of the a/c</TD></TR></TABLE>
thought about that, but i only paid $200 for this thing, no matter what i do, i should get more out of it if i sell... lol
The relays im not actually that worried about, its the long loomed wires coming out of them, running the length of the radiator over to where the a/c compressor usually is. i dont see any reason tucking wires im never gonna use again. i just want them out.
just follow the wires back to the fuse box. the run alone the pass side frame rail and plug into the fuse box, then you can remove the whole harness. there will also be a couple of wires running through the fire wall and under the dash, but i cut these off with enough room to splice, incase i want ac back. Its very easy
remember that "AC" was a dealer option back then, so they had to make it moduler, for ease of installation. so it will all come out in one piece
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrtoastyjr »</TD></TR><TR><TD CLASS="quote">remember that "AC" was a dealer option back then, so they had to make it moduler, for ease of installation. so it will all come out in one piece</TD></TR></TABLE>
thanks
thanks
Ep1dem1c
18
May 26, 2007 06:44 AM
iphatcrxi
Jun 14, 2006 12:36 AM
