PLEASE HELP: RSX-S oil change question
sorry for the noobie question, i tried searchin and didn't get an answer. anyway, I just changed my oil (mobile 1 5w 30 with mobile 1 oil filter). The manual says to use 4.8 qt (which is about 5 bottles at 1 qrt each), which I did. But when i checked my dipstick, it shows very little to no oil. I checked the dipstick about 5 min after the change.
My quesiton is: should i use more than 5 bottles? How many bottles should I use?
I have a Type S btw.
^ if it doesnt turn off you're in the clear?
no the oil pressure light is a bad indication of how much oil your car has. you should check on a level surface of course, 5 qts should do it.
i dont think you guys answered any of his question. when you put in brand new oil, you should not be able to really tell where the line is because it won't be dark enough. you'd have to hold it at an angle in a lighted area to see it. and for the most part, you will see it on the edge of the dipstick.
fryguy190
Jan 1, 2009 07:51 AM
