Using Honda MTF with LSD Tranny
I've noticed there are all sorts of companies making LSD oils for LSD trannies such as http://www.passwordjdm.com/pro...D=367. Just wondering if Honda MTF is sufficient enough for LSD trannies?
I think the Kazz LSD requires a special oil. I think it varies by manufacturer. Did you look it up?
Modified by mkazm83 at 7:09 PM 3/11/2006
aftermarket differentials require aftermarket transmission fluid. the bad part about that is a tin of kaaz diff fluid costs you about ~40 bucks
edit: and you'll be fine using honda mtf on your m2b4. honda mtf is the shiznitz
you ONLY need special additives for clutch type LSDs, like KAAZ..
Gear (quaife/obx/oem honda LSD and NON LSD) differentials just use standard MTL Same with honda's viscous LSD.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda318dx »</TD></TR><TR><TD CLASS="quote">you ONLY need special additives for clutch type clutches, like KAAZ..
Gear (quaife/obx/oem honda LSD and NON LSD) differentials just use standard MTL Same with honda's viscous LSD.</TD></TR></TABLE>
cool, thanx for the input guys
IA93Vteclude
May 19, 2002 01:00 PM
