BOOM!!! (HOUSTON WE HAVE A PROBLEM) turbo techs please read
Old Mar 11, 2006 | 12:59 PM
conceptEG's Avatar
Default BOOM!!! (HOUSTON WE HAVE A PROBLEM) turbo techs please read
ok..a friend of mine bought a fully built 00 prelude..
heres the long list of modds..
fully built h22a with darton ductile sleeves..
eagle rodds
arp bolts
cp frged pistons 9.5:1 cr
cnc p&p head milti angle valve job with stainless steel valves ti' v/springs and retainers
rc750 peak and hold injectors
innovitative 60-1 dual bb turbo stage 5 .58a/r tangential w/v
t04/60-1 rated to 600hp
42mm wastegate greddy fmic
toda v tec killer cams
aem ems stand alone ecu,aem fuel rail
msbc multi stage boost controller
aem uego gauge type wide band controller
clutchmaster stage 7 carbon clutch with quaffe lsd
3' dp
greddy type s bov
and tons of other sh**
well my boy threw a rodd through a block today..cylender 3
the head if fine.. valves and seals are ok..the head seems untouched
i dont know what happened but theres a hole in the block 2 inches in diameter
he just wants a new short block pre built if possible..where can i get one?
and as for a fixing the car itself what would be the cheapest route?
he got the car through e bay from the northern va area.. the car is sweet and well worth what he paid..
dyno numbers were nice..497hp with 391 ft lbs of tqe
its sitting now i will post pics soon.. to tell you the truth i dont know where to start.
Old Mar 11, 2006 | 02:27 PM
Rudaluda's Avatar
with a built block and EMS how the hell do you throw a rod!
Old Mar 11, 2006 | 03:09 PM
championshipwhite93si's Avatar
Default Re: (Rudaluda)
probably snapped a rod bolt....but then again who knows
Old Mar 11, 2006 | 04:12 PM
Turbo Lude SH's Avatar
Before he even thinks about getting a new shortblock he needs to figure out what happened. Because most likely, the same thing is just going to happen to his new one.
But maybe the guy who sold it to him knew it was on its last leg and thats why he sold it. Who knows.
A search will get you some info on pre-built H22's.
Old Mar 11, 2006 | 06:30 PM
Not_Rice4ws's Avatar
hrmm interesting. another #3 rod thrown. ive heard more stories of that rod snapping... a friend of mine once told me that when honda did there stress tests on stock oilers, it was always the #3 squirter that wouldnt put out as much oil as needed, and that rod bearing was the one that failed first. who knows if he got it from the back of a mag. or from someone who actually knows.
all i can say is its interesting that ive seen more and more of the same with #3 and not the other rods
Old Mar 11, 2006 | 07:40 PM
Mykizism's Avatar
i spun a bearing once.. guess what .. it was cylinder 3 as well
Old Mar 12, 2006 | 06:04 AM
PrecisionH23a's Avatar
Default Re: BOOM!!! (HOUSTON WE HAVE A PROBLEM) turbo techs please read (hatr-aid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatr-aid &raquo;</TD></TR><TR><TD CLASS="quote">
eagle rodds
That's my guess. Was he running the 7/16th bolts or 3/8s?
Cylinder #3 always runs the hottest because of the firing order of our engines, 1,3,4,2.
If he is interested, I am selling an 88mm darton sleeved MID h23a block. He could go h23vtec and make a little bit more power on his next set-up.
Old Mar 18, 2006 | 07:09 PM
mugenmarauder's Avatar
Default Re: BOOM!!! (PrecisionH23a)
How much for the block?
Old Mar 18, 2006 | 09:04 PM
plikit's Avatar
Default Re: BOOM!!! (mugenmarauder)
ive snapped a rod before too!!
cylinder 3...
slick1851
Jul 24, 2010 10:30 AM
slick1851
Jul 1, 2010 09:19 PM
B18 CYA
May 22, 2004 11:22 AM
boostedrs97
Jun 5, 2003 08:07 AM
Boostless97Lude
Sep 9, 2002 05:30 PM
