h22 pistons..?
Not sure if any1 has mentioned this but i was told to ask here :D
OK so i found these pistons, they are called MAHLE GOLDSERIES PISTON SET: H22 (87.25MM BORE 9.0/1) it sais no need sleeving, will handle more boost...is that true, well here is a link .... http://www.robearracing.com/pd...s.cfm Well what u guys think, have any of u tryed these pistons out here, id like to know thanx
yes, i've read that apparently mahle has special coatings on their pistons that allow them to be used without sleeving the block.
